Firewall Filters
2 quick questions:
  1. Is the firewall Filter a top down list ? first rule match ?
  2. Can i log a matched filter ?
thanks in advance
  1. Yes
  2. Yes, just create a rule with the same matchers and action=log before the rule you want to log.
Sent from my LG-D800 using Tapatalk
If i use a log action first will it still execute the following rule with a drop action ? o
r will it just stop at rule 1 because we had a match?
You can have the rule log
below the rule performing an action as Drop, Rejet or Acept
