firewall - fixed "address-list" entry changing from IP to DNS and vice versa;
Hello friends.
How often is the dns entry updated if we put a domain in the addess-list?
I mean the update that was introduced in the 6.40 release:
firewall - fixed “address-list” entry changing from IP to DNS and vice versa;
Thanks.
This feature was introduced in an earlier version, the change note you reference is the fix of a bug in that feature.
The time between updates is equal to the TTL field of the DNS record. So you can set that in your DNS server.
Thanks in advance, but how often do you consult the address list to the dns?
