firewall for 200 users
i wanted to know if i can use CCR1009-8G-1S-1S+ as a firewall for a 200 user network??
You can use it for 4000 user network…
How if you have a masquerade (nat) firewall not only spi ??
Is there a sufficient number of ports ??
If you NAT all the traffic, you can use 32768** ports for each public IP assigned to CCR,
assuming your client are using each one 32 ports*** concurrently, you can put on CCR 1024 users for each single public IP address you have on CCR.
**(really 32768 UDP + 32768 TCP for each public IP)
***(32 UDP + 32 TCP)
