Hi there,
I’m using the MikroTik firewall and hotspot system and have a problem. My firewall has some rules to block access to specific websites, but only in the network range 192.168.10.100-192.168.11.254. There are computers that have a static IP below that range, 192.168.10.90 for example.They should have access to these websites and generally this works fine.
However, if I activate the Hotspot function these clients are also blocked from accessing all websites and I don’t know why. Somehow, even with an IP address of 192.168.10.90 the rule above kicks in. If I disable the rule, everything is fine. If I disable the Hotspot, it’s fine too. Any ideas?
