firewall log parse
Hello there. I want to break the message I received on the screen with the firewall log. I need to save the following data to different fields saved in Mysql e. Can you help me?
in: out: vlan1, src-mac 4c: 5e: 0c: 0c: 0c: 0c, proto TCP (ACK), 192.168.1.5:47694->74.125.154.73:443, NAT (192.168.1.5 : 47694-> 123.123.123.123:15400) → 74.125.154.73:443, len 52
mysql register should be as follows
1 column : user1
2 column : 4c: 5e: 0c: 0c: 0c: 0c
3 column : 192.168.1.5:47694
4 column : 74.125.154.73:443
5 column : 123.123.123.123:15400
6 column : 74.125.154.73:443
