Firewall LOG problem
Hi.
I have a strange problem which I was unable to resolve. I’m trying to log all outgoing traffic to a specific IP. Making a firewall rule is simple, dst-address=91.202.65.130, log rule with a prefix. I put this rule in the first positon under firewall filter rules. The thing is when I apply this rule it logs perfectly all data, but only on a specific port on a router (bridge1). On other ports if fails to log src-mac-address, instead it skipps it. I see all the devices in ARP table on the router, that are trying to connect to 91.202.65.130.
e.g.:
Sep/20/2011 18:06:29 firewall,info 24ur forward: in:Bridge-LAN out:VDSL, src-mac 6c:f0:49:77:df:03, proto ICMP (type 8, code 0), 10.22.22.233->91.202.65.130, len 84
Sep/20/2011 18:06:30 firewall,info 24ur forward: in:Bridge-LAN out:VDSL, src-mac 6c:f0:49:77:df:03, proto ICMP (type 8, code 0), 10.22.22.233->91.202.65.130, len 84
Sep/20/2011 18:06:31 firewall,info 24ur forward: in:Bridge-LAN out:VDSL, src-mac 6c:f0:49:77:df:03, proto ICMP (type 8, code 0), 10.22.22.233->91.202.65.130, len 84
Sep/20/2011 18:06:32 firewall,info 24ur forward: in:Bridge-LAN out:VDSL, src-mac 6c:f0:49:77:df:03, proto ICMP (type 8, code 0), 10.22.22.233->91.202.65.130, len 84
Sep/20/2011 18:06:33 firewall,info 24ur forward: in:Bridge-LAN out:VDSL, src-mac 6c:f0:49:77:df:03, proto ICMP (type 8, code 0), 10.22.22.233->91.202.65.130, len 84
Sep/20/2011 18:06:34 firewall,info 24ur forward: in:Bridge-LAN out:VDSL, src-mac 6c:f0:49:77:df:03, proto ICMP (type 8, code 0), 10.22.22.233->91.202.65.130, len 84
Sep/20/2011 18:06:40 firewall,info 24ur forward: in:ether8 out:VDSL, proto ICMP (type 8, code 0), 10.2.20.3->91.202.65.130, len 50
Sep/20/2011 18:06:42 firewall,info 24ur forward: in:ether8 out:VDSL, proto ICMP (type 8, code 0), 10.2.20.3->91.202.65.130, len 50
Sep/20/2011 18:06:45 firewall,info 24ur forward: in:ether8 out:VDSL, proto ICMP (type 8, code 0), 10.2.20.3->91.202.65.130, len 50
Sep/20/2011 18:06:46 firewall,info 24ur forward: in:ether8 out:VDSL, proto ICMP (type 8, code 0), 10.2.20.3->91.202.65.130, len 50
Sep/20/2011 18:06:47 firewall,info 24ur forward: in:ether8 out:VDSL, proto ICMP (type 8, code 0), 10.2.20.3->91.202.65.130, len 50
Sep/20/2011 18:06:48 firewall,info 24ur forward: in:ether8 out:VDSL, proto ICMP (type 8, code 0), 10.2.20.3->91.202.65.130, len 50
Sep/20/2011 18:06:49 firewall,info 24ur forward: in:ether8 out:VDSL, proto ICMP (type 8, code 0), 10.2.20.3->91.202.65.130, len 50
Any clues?
What does your logging rule look like?
0 chain=forward action=log dst-address=91.202.65.130 log-prefix=“24ur”
@bysard
AFAIK MAC address is logged only for bridged interfaces.
Regards,
ditonet you are right. Dunno why but it really only logs MAC addresses from bridge devices. Thank you for this answer. Helped me a lot.
