Firewall\Nat port forward
Hi everyone,
I would like to create a port forwarding (From my external IP (ISP) to my internal network)
I read this page https://wiki.mikrotik.com/wiki/Manual:Initial_Configuration#Static_configuration
So this bring two questions :
  1. My Dst adresse is the IP from my ISP who is dynamic, is there any variable that I can put in this field (who contain the current ISP provided IP ?) or any way to do this ?
  2. what it’s the little checkbox in front of the IP
“what it’s the little checkbox in front of the IP”
it means “NOT”, so basically you say “not any source”
Thank you @vilpalu
so 0.0.0.0 by default in ROS many any IP correct ?
But If I let that as □ 0.0.0.0 (unchecked) it mean that all IP incoming dst IP will be accepted. how can I define the current ISP IP ?
Mainly, 172.16.88.67 is not public address. So unless you are sure that ISP gives you one (could be done with NAT 1:1 or something where the real address would be on their router), there will be no port forwarding or any other access from internet to you.
On my dstnat (port forwarding rule) I used in-interface-list=WAN (since I have dual wan), if I had a single wan it would have been in-interface=wan.
Note, if you know the limited WANIPs external that need access to your server then you could add them to an address list
and they would be under source-address-list=“authorized_server_access”
What is also required is a firewall forward chain rule.
Basically states allow new connections and new-connection-dstnat connections from your wan interface (or wan interface list if dual).
