Firewall No P2P Option
Hello.
Im trying to block P2P. However, when i trying to create new Rule. P2P option is not available.
I check some videos and they have this option. Is this related to license? Im using Level 4 license RB951Ui-2HnD
p2p firewall matcher has been deprecated.
http://forum.mikrotik.com/t/v6-39-current/108334/65
This is noted.
But how can I block all p2p?
The short answer is you can’t block all p2p. You never could, and you probably never will.
The long answer is, maybe you can. Some of them… It depends on what you need to do.
Search the forum and the wiki. There are numerous methods of blocking p2p.
Thank you so much Sir.
