Hi, based on this post I started to experiment with the Mikrotik Hex PoE firewall in combination with VLANs. But I fail to understand what to expect from this setup.
Network/Mikrotik setup
I have the following config:
/export hide-sensitive
# jun/12/2022 12:10:24 by RouterOS 7.3.1
# software id = A1GI-TFVF
# model = 960PGS
# serial number = 89F90861A06A
add admin-mac=CC:2D:E0:81:0A:BE auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] poe-out=forced-on
set [ find default-name=ether3 ] poe-out=forced-on
set [ find default-name=ether4 ] poe-out=forced-on
set [ find default-name=ether5 ] poe-out=forced-on
set 0 default-vlan-id=10 vlan-mode=secure
set 1 default-vlan-id=10 vlan-mode=secure
set 2 default-vlan-id=10 vlan-mode=secure
set 3 default-vlan-id=10 vlan-mode=secure
set 4 default-vlan-id=10 vlan-mode=secure
set 5 default-vlan-id=10 vlan-mode=secure
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=yes interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
/ip settings
set rp-filter=strict
add comment=native independent-learning=yes ports=ether1,ether2,ether3,ether4,ether5,switch1-cpu switch=switch1 vlan-id=10
add comment=management independent-learning=yes ports=ether2,ether3,ether4,ether5,switch1-cpu switch=switch1 vlan-id=11
add comment=replication independent-learning=yes ports=ether2,ether3,ether4,ether5,switch1-cpu switch=switch1 vlan-id=12
add comment=public independent-learning=yes ports=ether2,ether3,ether4,ether5,switch1-cpu,ether1 switch=switch1 vlan-id=13
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=log chain=output connection-state=new,untracked log=yes log-prefix="LOG ALL"
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid log=yes
add action=log chain=input connection-state=new,untracked log=yes log-prefix="LOG ALL"
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes hw-offload=yes
add action=accept chain=forward connection-state=new,untracked protocol=icmp
add action=log chain=forward connection-state=new dst-address=172.27.13.0/24 dst-port=80,443 log=yes log-prefix="DROP WEB" protocol=tcp
add action=log chain=forward connection-state=new,untracked log=yes log-prefix="LOG ALL"
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes ipsec-policy=out,none out-interface-list=WAN
add disabled=no dst-address=172.27.13.0/24 gateway=ether1 routing-table=main suppress-hw-offload=no
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=rt2
/tool mac-server
/tool mac-server mac-winbox
With this routing:
/ip/route/print
Flags: D - DYNAMIC; A - ACTIVE; c, s, d, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
# DST-ADDRESS GATEWAY DISTANCE
DAd 0.0.0.0/0 172.27.10.1 1
DAc 172.27.10.0/24 ether1 0
0 As 172.27.13.0/24 ether1 1
As you can see I placed some log rules in the firewall for input, output and forward. This is to identify what is picked up by the firewall and what isn’t.
My network looks like this:
Workstation → layer 2 switch → ISP provider modem/router → ether1 (Mikrotik) → ether2 (Mikrotik)
As you can also see in the VLAN setup, VLAN 10 is the native VLAN. ether2-5 have VLAN 11-13 only for themselves. I only added the switch1-cpu to the VLANs for experimentation.
Native VLAN has 172.27.10.0/24 as subnet. The other VLANs have 172.27.{11,12,13}.0/24.
172.27.10.1 is my ISP modem/router. 172.27.10.3 is my Mikrotik. 172.27.10.100 is my workstation. 172.27.{10,11,12,13}.11 is a host connected to ether2.
Firewall
The following is or is not registered by the firewall.
- input: in:ether1 out:(unknown 0), proto 2, 172.27.10.1->224.0.0.1
- input: in:ether1 out:(unknown 0), proto UDP, 172.27.10.1:53805->255.255.255.255:53805
- input: in:ether1 out:(unknown 0), proto ICMP (type 8, code 0), 172.27.10.100->172.27.10.3
- input: in:ether1 out:(unknown 0), proto TCP (SYN), 172.27.10.100:51176->172.27.10.3:18988 (and basically any traffic going from my workstation to ether1)
- output: in:(unknown 0) out:ether1, proto TCP (SYN), 172.27.10.3:46702->159.148.172.226:80 (and basically any traffic going out from ether1, initiated by the Mikrotik, not the connected hosts)
- An nmap scan from my workstation to 172.27.10.11 (ether2) does not show up in the firewall logs, the host is reachable though
- An nmap scan from 172.27.10.11 to my workstation does not show up in the firewall logs, host is reachable
- A ping from 172.27.10.11 to the Mikrotik (172.27.10.3) results in a (Destination Host Unreachable), the default gateway is set to 172.27.10.1 (so it should get a route and back).
- A ping from my workstation to 172.27.13.11 (ether2) also has some routing issues (see next section for details), but reaches the destination eventually, however, this is not picked up by the Mikrotik firewall either
- An nmap scan from my workstation to 172.27.13.11 (ether2) also does not result in firewall logs on the Mikrotik
It seems like ether1 to ether2 traffic is not picked up at all. Could this be part of a routing issue? Or has this to do with offloading the VLAN networks (layer 2) to hardware and thus doesn’t get processed by the firewall which uses the CPU?
Routing issue
A ping from my workstation to a VLAN on ether2 is a bit flaky due to a routing issue. But eventually the ping does work. This is likely due to asymmetric routing. What would be a good fix for this in this situation?
$ ping 172.27.13.11
PING 172.27.13.11 (172.27.13.11) 56(84) bytes of data.
From 172.27.10.1 icmp_seq=1 Redirect Host(New nexthop: 172.27.10.3)
From 172.27.10.3 icmp_seq=1 Redirect Host(New nexthop: 172.27.13.11)
From 172.27.10.3 icmp_seq=2 Redirect Host(New nexthop: 172.27.13.11)
64 bytes from 172.27.13.11: icmp_seq=3 ttl=64 time=0.361 ms
64 bytes from 172.27.13.11: icmp_seq=4 ttl=64 time=0.368 ms
From 172.27.10.3 icmp_seq=1 Destination Host Unreachable
From 172.27.10.3 icmp_seq=2 Destination Host Unreachable
64 bytes from 172.27.13.11: icmp_seq=5 ttl=64 time=0.310 ms
64 bytes from 172.27.13.11: icmp_seq=6 ttl=64 time=0.342 ms
64 bytes from 172.27.13.11: icmp_seq=7 ttl=64 time=0.272 ms
^C
--- 172.27.13.11 ping statistics ---
7 packets transmitted, 5 received, +5 errors, 28.5714% packet loss, time 6161ms
rtt min/avg/max/mdev = 0.272/0.330/0.368/0.035 ms, pipe 4
My workstation has these routes:
ip route
default via 172.27.10.1 dev enp4s0u1u4 proto dhcp src 172.27.10.100 metric 100
default via 172.27.10.1 dev wlp0s20f3 proto dhcp src 172.27.10.5 metric 600
172.27.10.0/24 dev enp4s0u1u4 proto kernel scope link src 172.27.10.100 metric 100
172.27.10.0/24 dev wlp0s20f3 proto kernel scope link src 172.27.10.5 metric 600
The Mikrotik has these routes:
/ip/route/print
The destination host on ether3 has these routes:
ip route
default via 172.27.10.1 dev eth0 onlink
172.27.10.0/24 dev eth0 proto kernel scope link src 172.27.10.11
172.27.11.0/24 dev eth0.11 proto kernel scope link src 172.27.11.11
172.27.12.0/24 dev eth0.12 proto kernel scope link src 172.27.12.11
172.27.13.0/24 dev eth0.13 proto kernel scope link src 172.27.13.11
The ISP modem/router is the DHCP of the 172.27.10.0/24 network and thus sets dynamic routes.
It does have a static route set:
