FIREWALL Problem - Abuse from ISP - Hacking Virus Trojan
I have a Problem, I use a MT RB750GL 5.24 and today I got an email from my ISP which told me, that someone in my LAN use my I-Net Connection for hacking attacks.
I cannot find anything on my devices, the androids and windows clients were scanned today, 100% no infection or something else.
Is there someone who can explain me, how to find out the infected client?
I found one connection in my connection-list which scares me a little…
and above see my firewall settings…
 2   ;;; Accept established connections
     chain=input action=accept connection-state=established
 3   ;;; Accept related connections
     chain=input action=accept connection-state=related
 4   ;;; Drop invalid connections
     chain=input action=drop connection-state=invalid
 5   ;;; Allow limited pings
     chain=input action=accept protocol=icmp limit=50/5s,2
 6   ;;; Drop excess pings
     chain=input action=drop protocol=icmp
 7   ;;; From our LAN
     chain=input action=accept src-address=192.168.100.0/24 in-interface=ether2
12   ;;; Log everything else
     chain=input action=log log-prefix="DROP INPUT"
13   ;;; Drop everything else
Thanks for your help.
If you suspect one of your localnet computers, you should be watching the forward chain also. If you know the ip of the victim, it should be easy to tell who it is.
Hi, thanks for your answer, it must be one client in the local network. Who else could it be, normaly the fw should filter this?
Here we have 30 devices, Smartphones, Android, iPhone, Tablets, MediaCenter, Win7 and Ubuntu etc.
Is it possible to save the logs from the hole day automatic to a txt file?
thx
That first entry indicates a connection from a Carrier NAT address to a Google server which might mean that somebody is relaying through you.
You could upload output from /export compact for a better interpretation. If you want a faster resolution drop me an email and I can have a live look at the router in question.
It will if you add the rules to filter it. By default, there is no firewall filtering for forward chain. The input chain only blocks or allows connections to the router. You need to block the forward chain (in one interface and out another) to get the desired result. Something like this if 1.2.3.4 is the hacking victim IP:
add chain=forward action=drop dst-address=1.2.3.4
You might want to add a log or address-list entry to that like your input rule.
