firewall problem need urgent help
I accidently deleted all of my input rules except for drop everything else on input. do I need to do a netinstall or what. please help thanks
You may try to get access with Null modem cable or MAC-Winbox/Telnet, then disable this rule.
thanks for the fast reply. I will give that a shot and let you know what happens.
thanks again for the fast response and winbox with mac worked. I figured all methods were disabled with that rule. thanks
Firewall Filters don’t apply to layer2.
GWISA-Kroonstad,
yes, ip firewall does not block MAC-Winbox, you need to disable MAC-server to disalow MAC-Winbox connection.
