Firewall Problem
Dear All,
I’ve a problem with a firewall filter rule
 0   ;;; default configuration
     chain=input action=accept protocol=icmp
 1   ;;; default configuration
     chain=input action=accept connection-state=established
 2   ;;; default configuration
     chain=input action=accept connection-state=related
 3   ;;; WINBOX ACCESS
     chain=input action=accept protocol=tcp src-address-list=cybNET dst-port=8291
 4 X chain=input action=accept protocol=tcp src-address-list=cybNET dst-port=8888
 5   ;;; CAMERA ACCESS
     chain=forward action=accept protocol=tcp src-address-list=any dst-port=8880
 6   chain=forward action=accept protocol=tcp src-address-list=any dst-port=554
 7   ;;; LAN TO TILFF
     chain=forward action=accept src-address=192.168.12.0/24 dst-address=192.168.10.0/24
 8   chain=forward action=accept connection-state=established src-address=192.168.10.0/24 dst-address=192.168.12.0/24
 9   chain=forward action=accept connection-state=related src-address=192.168.10.0/24 dst-address=192.168.12.0/24
10   ;;; TILLF TO LAN
     chain=forward action=accept src-address=192.168.10.0/24 dst-address=192.168.12.0/24
11   chain=forward action=accept connection-state=established src-address=192.168.12.0/24 dst-address=192.168.10.0/24
12   chain=forward action=accept connection-state=related src-address=192.168.12.0/24 dst-address=192.168.10.0/24
13   ;;; LAN TO WAN
     chain=forward action=accept in-interface=bridge-local out-interface=pppoe-out1
14   chain=forward action=accept connection-state=established in-interface=pppoe-out1 out-interface=bridge-local
15   chain=forward action=accept connection-state=related in-interface=pppoe-out1 out-interface=bridge-local
16   ;;; VLAN100 TO WAN
     chain=forward action=accept in-interface=vlan100 out-interface=pppoe-out1
17   chain=forward action=accept connection-state=established in-interface=pppoe-out1 out-interface=vlan100
18   chain=forward action=accept connection-state=related in-interface=pppoe-out1 out-interface=vlan100
19   chain=forward action=log log-prefix=""
20   ;;; default configuration
     chain=input action=drop in-interface=pppoe-out1
21   [b]chain=forward action=drop
[/b]
NAT
 0   ;;; IPSec
     chain=srcnat action=accept src-address=192.168.12.0/24 dst-address=192.168.10.0/24
 1   ;;; CAMERA ACCESS
     chain=dstnat action=dst-nat to-addresses=192.168.12.240 to-ports=81 protocol=tcp dst-port=8880
 2   chain=dstnat action=dst-nat to-addresses=192.168.12.240 to-ports=554 protocol=tcp dst-port=554
 3   ;;; B-BOX ACCESS
     chain=srcnat action=masquerade out-interface=ether1-gateway
 4   ;;; default configuration
     chain=srcnat action=masquerade out-interface=pppoe-out1
I can not access my camera from outside. When i disable the last rule (dorp forward) it’s working.
Where is the problem?
Thank you in advance,
there is a few things, firstly you allow, one port then forward another
i dont see the allow for the port 81, since thats your redirect, i would rather redirect the correct port from the outside to the inside, some recorders forward the “port” as an embeded message in the connection stream,
1 ;;; CAMERA ACCESS
You dont need the address list, and also try tcp and udp for 554 - rstp can be elusive like that.
odds are that you dropping :81 traffic coz you are not allowing it.
5 ;;; CAMERA ACCESS
