Hi, Is my firewall good enough to protect me and my router from outside? I got public IP
# model = RBD52G-5HacD2HnD
# serial number = B4A00A643903
add admin-mac=24:4D:28:E2:13:14 arp=reply-only auto-mac=no comment=defconf \
dhcp-snooping=yes name=bridge
add admin-mac=4A:dA:58:88:2B:61 arp=reply-only auto-mac=no dhcp-snooping=yes \
name=bridge2
add admin-mac=F1:44:66:45:AD:DC arp=reply-only auto-mac=no dhcp-snooping=yes \
name=bridge3
/interface wireless
set [ find default-name=wlan1 ] arp=reply-only band=2ghz-b/g/n channel-width=\
20/40mhz-XX country=poland default-forwarding=no disabled=no distance=\
indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
"Vectra 2.4" wireless-protocol=802.11 wps-mode=disabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk disable-pmkid=yes \
eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik \
wpa2-pre-shared-key=x
add authentication-types=wpa2-psk disable-pmkid=yes eap-methods="" mode=\
dynamic-keys name=WIFI2 supplicant-identity="" wpa2-pre-shared-key=\
"x
/interface wireless
set [ find default-name=wlan2 ] arp=reply-only band=5ghz-a/n/ac \
channel-width=20/40/80mhz-XXXX country=poland default-forwarding=no \
disabled=no distance=indoors installation=indoor mode=ap-bridge \
security-profile=WIFI2 ssid="Vectra 5 Ghz" wireless-protocol=802.11 \
wps-mode=disabled
/ip ipsec mode-config
add connection-mark=no-mark name=Vpn responder=no src-address-list=local
/ip ipsec policy group
add name=KeepSolid
/ip ipsec profile
add dh-group=modp3072 enc-algorithm=aes-256 hash-algorithm=sha512 name=Vpn
/ip ipsec peer
add address=33.130.136.234/32 disabled=yes exchange-mode=ike2 name=Vpn \
profile=Vpn
/ip ipsec proposal
add auth-algorithms=sha512 enc-algorithms=aes-256-gcm name=Vpn pfs-group=\
modp3072
add name=pool2 ranges=192.168.2.10-192.168.2.20
add name=pool3 ranges=192.168.3.19-192.168.3.20
add add-arp=yes address-pool=default-dhcp disabled=no interface=bridge name=\
defconf
add address-pool=pool2 disabled=no interface=bridge2 name=dhcp2
add address-pool=pool3 disabled=no interface=bridge3 name=dhcp3
/system logging action
add disk-file-count=5 disk-file-name=/disk1/log disk-lines-per-file=10000 \
name=usb target=disk
add disk-file-name=auth.log disk-lines-per-file=5000 name=auth target=disk
add email-to=x name=email target=email
add bridge=bridge2 comment=defconf interface=ether3
add bridge=bridge2 comment=defconf interface=ether4
add bridge=bridge2 comment=defconf interface=ether5
add bridge=bridge3 comment=defconf interface=wlan1
add bridge=bridge2 comment=defconf interface=wlan2
/interface bridge settings
set use-ip-firewall=yes
set discover-interface-list=none
/ip settings
set rp-filter=strict tcp-syncookies=yes
add interface=bridge2 list=LAN
add interface=bridge3 list=LAN
192.168.88.0
add address=192.168.2.1/24 interface=bridge2 network=192.168.2.0
add address=192.168.3.1/24 interface=bridge3 network=192.168.3.0
/ip arp
add address=192.168.88.254 interface=bridge mac-address=x
add address=192.168.3.20 interface=bridge3 mac-address=x
add address=192.168.3.19 interface=bridge3 mac-address=x
add address=192.168.2.20 interface=bridge2 mac-address=x
add address=192.168.2.19 interface=bridge2 mac-address=x
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
x
add address=192.168.2.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.2.1
add address=192.168.3.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.3.1
add address=192.168.88.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.88.1
set servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 comment=defconf disabled=yes name=router.lan
add address=8.8.8.8 name=rr
/ip firewall address-list
add address=192.168.3.10-192.168.3.20 list=local
add address=0.0.0.0/8 comment="defconf: RFC6890" list=no_forward_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=no_forward_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=no_forward_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=no_forward_ipv4
add address=127.0.0.0/8 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="defconf: RFC6890 documentation" list=\
bad_ipv4
add address=198.51.100.0/24 comment="defconf: RFC6890 documentation" list=\
bad_ipv4
add address=203.0.113.0/24 comment="defconf: RFC6890 documentation" list=\
bad_ipv4
add address=240.0.0.0/4 comment="defconf: RFC6890 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6890 benchmark" list=\
not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890" list=bad_dst_ipv4
add list=ddos-attackers
add list=ddos-target
add action=add-src-to-address-list address-list=SuspectPort_Scanner \
address-list-timeout=14w2d chain=input comment="Port Scanner Detect" \
fragment=no in-interface=ether1 log=yes log-prefix="port skan" protocol=\
tcp psd=19,5m,2,3
disabled=yes fragment=no in-interface=ether1 log=yes log-prefix=\
"port skan" protocol=udp psd=19,5m,2,3
add action=drop chain=input src-address-list=SuspectPort_Scanner
add action=drop chain=input dst-port=53 protocol=tcp
add action=drop chain=input dst-port=53 protocol=udp
established,related
invalid
add action=accept chain=input dst-port=x in-interface=bridge protocol=tcp
add action=drop chain=input comment="drop wszystko"
connection-state=established,related disabled=yes
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
established,related,untracked
connection-state=invalid
add action=drop chain=forward in-interface=bridge3 out-interface=bridge2
add action=drop chain=forward comment="defconf: drop bad forward IPs" \
src-address-list=no_forward_ipv4
dst-address-list=no_forward_ipv4
add action=accept chain=forward in-interface-list=LAN out-interface-list=WAN
add action=drop chain=forward log=yes log-prefix=\
"ostatnia regulka z forwarda,
add action=return chain=detect-ddos dst-limit=32,32,src-and-dst-addresses/10s \
log=yes log-prefix=dooos
add action=add-dst-to-address-list address-list=ddos-target \
address-list-timeout=10m chain=detect-ddos log=yes log-prefix=ddos
add action=add-src-to-address-list address-list=ddos-attackers \
address-list-timeout=10m chain=detect-ddos log=yes log-prefix=dddos
add action=accept chain=srcnat comment=\
"defconf: accept all that matches IPSec policy" disabled=yes \
/ip firewall raw
add action=accept chain=prerouting comment=\
"defconf: enable for transparent firewall"
add action=accept chain=prerouting comment="defconf: accept DHCP discover" \
dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=\
udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting comment="defconf: drop bogon IP's" \
src-address-list=bad_ipv4
dst-address-list=bad_ipv4
src-address-list=bad_src_ipv4
dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="defconf: drop non global from WAN" \
in-interface-list=WAN log-prefix="drop non global from wan" \
src-address-list=not_global_ipv4
add action=drop chain=prerouting comment=\
"defconf: drop forward to local lan from WAN" dst-address=192.168.88.0/24 \
"defconf: drop local if not from default IP range" in-interface=bridge \
log=yes src-address=!192.168.88.0/24
"defconf: drop local if not from default IP range" in-interface=bridge2 \
log=yes src-address=!192.168.2.0/24
"defconf: drop local if not from default IP range" in-interface=bridge3 \
log=yes src-address=!192.168.3.0/24
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 \
protocol=udp
add action=drop chain=prerouting dst-address-list=ddos-target log=yes \
log-prefix=ddos src-address-list=ddos-attackers
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" \
jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" \
jump-target=bad_tcp protocol=tcp
"defconf: accept everything else from LAN" in-interface-list=LAN
"defconf: accept everything else from WAN" in-interface-list=WAN
add action=drop chain=prerouting comment="defconf: drop the rest"
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp \
tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="defconf: TCP port 0 drop" port=0 \
protocol=tcp
add action=accept chain=icmp4 comment="defconf: echo reply" icmp-options=0:0 \
limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: net unreachable" \
icmp-options=3:0 protocol=icmp
add action=accept chain=icmp4 comment="defconf: host unreachable" \
icmp-options=3:1 protocol=icmp
add action=accept chain=icmp4 comment="defconf: protocol unreachable" \
icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 comment="defconf: port unreachable" \
icmp-options=3:3 protocol=icmp
add action=accept chain=icmp4 comment="defconf: fragmentation needed" \
icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 comment="defconf: echo" icmp-options=8:0 limit=\
add action=accept chain=icmp4 comment="defconf: time exceeded " icmp-options=\
11:0-255 protocol=icmp
add action=drop chain=icmp4 comment="defconf: drop other icmp" protocol=icmp
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip ipsec identity
add auth-method=eap certificate=\
226B28D2-C2B3-4507-B3F0-7C01AD574E09_pl_ikev2.crt_0 eap-methods=\
eap-mschapv2 generate-policy=port-strict mode-config=Vpn password=\
haslo peer=Vpn policy-template-group=KeepSolid username=\
x
/ip ipsec policy
add dst-address=0.0.0.0/0 group=KeepSolid proposal=Vpn src-address=0.0.0.0/0 \
template=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox port=42271
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Warsaw
/system logging
set 0 action=usb
set 1 action=usb
set 2 action=usb
set 3 action=usb
add action=auth topics=account
add action=email topics=account
/system ntp client
set enabled=yes primary-ntp=153.19.250.123
/tool bandwidth-server
set enabled=no
/tool e-mail
set address=smtp.gmail.com from=<x password=\
"x" port=587 start-tls=yes user=\
x
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
