Firewall routing masquerade security
Hello Forum
I found a security issue that I was not aware about it.
I always assumed that if I use the function source nat masquerade, no routing would be possible in-between in and out interfaces.
However, this is not the case.
Imagine the default configuration of a Mikrotik Routerboard 450G.
There you have two interfaces configured.
One as ether 1-gateway (WAN) and ether 2 master-local.
The ether 2 interface is configured with ip addr. 192.168.88.1 and the ether 1 interface as dhcp client. Also srcnat masquerade is configured for port address translation to ether 1 ip address. All source ip addresses are translated from LAN to the outside address.
If you configure a PC in the network range of the ether 1 interface and use the ether 1 ip address as the default gateway, the packets are routed from outside (WAN) to inside (LAN)
With a firewall rule it’s possible to stop this.
In the manuals I always have seen, that communication from outside interface to inside interface is only possible with a static NAT rule.
This not true! RB is still routing!
How do you handle your internet access?
How do you secure your WAN Interface?
best regards redblue
You need to set general drop rule at input and forward chain from wan side and allow only established and related connection packets to pass in from wan port. +other exceptions you want to allow. Routeros accepts connections by default if you do not set other rules.
I use a firewall. The default behaviour on the Mikrotiks is to accept everything.
