Firewall rule not activating once PPTP connects
RB450G - 6.13
I have a PPTP Server Binding interface for each user. I use the interface name in the firewall rule. There is an in and out rule for each interface. At some point recently the rule stopped automatically enabling once the PPTP connection was made. It still shows red unless I click the blue check box to enable it. Double-clicking the rule and viewing the interface it appears enabled.. ie not in italics. Once the user disconnects, the rule turns red as it should. User re-connects, rule stays red until I enable it again.
Any ideas?
I have the same problem since I upgraded to 6.13. The rule with the PPTP-binding interface become red when the connection broke, but stay red when te connection establishes again.
The previous version worked well.
It is a bug that has apparently been fixed in the 6.14beta. Email support@mikrotik.com for the update package.
I had read that the 6.14 beta fixed this issue. I received it last night. Didn’t fix it for me.
Having the same problem here since the 6.13 upgrade on 2 x86 VMs.
Happy to see that it will be fixed in 6.14, hopefully not too far from now … :slight_smile:
Same problem with 6.13. Please fix ASAP.
Regards
Pasquale
It is fixed :slight_smile:.
OK, it’s a news.
It will be a more good news when the fix will be available. :smiley: :smiley: :smiley:
Regards
Pasquale :
It is indeed fixed for PPTP for me in 6.14rc25. Email support for this release if you cant wait for the official.
