Hello Guys,
I have a strange problem in my Mikrotik configuration that is making hard times for me ![]()
I have segmented my network in some vlans, and everything is working fine except one firewall rule. I have create a Firewall rule where I block the connection from all Vlans to communicate with each other and some other rules to allow the communication with some specific IPs. But when I create and rule to allow me as System Admin to communicate with all Vlans it is not working and I cannot reach other vlans.
Did that happened to anyone of you before that can help me with this issue.?
# apr/04/2022 11:11:36 by RouterOS 6.49.5
# software id = 6511-TAFJ
# model = CCR1016-12G
add arp=proxy-arp name=bridge1
set [ find default-name=ether4 ] comment="Main WAN" name=\
"Kujtesa WAN - Ether4"
set [ find default-name=ether2 ] comment="Backup WAN" name="Telkos Ether2"
set [ find default-name=ether8 ] comment="Wifi Link - Ether 8" name=Wifi
set [ find default-name=ether9 ] arp=proxy-arp
set [ find default-name=ether10 ] arp=proxy-arp
set [ find default-name=ether11 ] arp=proxy-arp comment=LAN
/interface vlan
add interface=Wifi name=Vlan101-WifiGuest vlan-id=101
add interface=ether11 name=vlan10 vlan-id=10
add interface=ether11 name=vlan20 vlan-id=20
add interface=ether11 name=vlan30 vlan-id=30
add interface=ether11 name=vlan40 vlan-id=40
add interface=ether11 name=vlan50 vlan-id=50
add interface=ether11 name=vlan60 vlan-id=60
add interface=ether11 name=vlan70 vlan-id=70
add interface=ether11 name=vlan80 vlan-id=80
add interface=ether11 name=vlan90 vlan-id=90
add interface=ether11 name=vlan99 vlan-id=99
add interface=ether11 name=vlan100 vlan-id=100
add interface=ether11 name=vlan110 vlan-id=110
add interface=ether11 name=vlan120 vlan-id=120
add interface=ether11 name=vlan130 vlan-id=130
add interface=ether11 name=vlan140 vlan-id=140
add interface=ether11 name=vlan150 vlan-id=150
add interface=ether11 name=vlan160 vlan-id=160
add interface=ether11 name=vlan170 vlan-id=170
add interface=ether11 name=vlan200 vlan-id=200
add interface=ether11 name=vlan1000 vlan-id=1000
add name=dhcp_pool1 ranges=10.1.1.11-10.1.1.190
add name=openvpn-pool ranges=10.1.1.191-10.1.1.199
add name=dhcp_pool3 ranges=192.168.100.2-192.168.100.240
add name=dhcp_pool11 ranges=192.168.101.20-192.168.101.200
add name=dhcp_pool12 ranges=10.1.10.100-10.1.10.120
add name=dhcp_pool13 ranges=10.1.20.100-10.1.20.120
add name=dhcp_pool14 ranges=10.1.30.100-10.1.30.120
add name=dhcp_pool15 ranges=10.1.70.100-10.1.70.120
add name=dhcp_pool16 ranges=10.1.80.100-10.1.80.120
add name=dhcp_pool17 ranges=10.1.90.100-10.1.90.120
add name=dhcp_pool18 ranges=10.1.100.100-10.1.100.120
add name=dhcp_pool19 ranges=10.1.110.100-10.1.110.120
add name=dhcp_pool20 ranges=10.1.120.100-10.1.120.120
add name=dhcp_pool21 ranges=10.1.130.100-10.1.130.120
add name=dhcp_pool22 ranges=10.1.140.100-10.1.140.120
add name=dhcp_pool23 ranges=10.1.150.100-10.1.150.120
add name=dhcp_pool24 ranges=10.1.160.100-10.1.160.120
add name=dhcp_pool25 ranges=10.1.170.100-10.1.170.120
add name=dhcp_pool26 ranges=10.1.40.100-10.1.40.120
add name=dhcp_pool27 ranges=10.1.50.100-10.1.50.120
add name=dhcp_pool28 ranges=10.1.60.100-10.1.60.120
add name=dhcp_pool29 ranges=10.1.200.100-10.1.200.120
add address-pool=dhcp_pool1 allow-dual-stack-queue=no conflict-detection=no \
disabled=no interface=vlan1000 lease-time=1d10m name="LAN dhcp" \
src-address=10.1.1.1
add address-pool=openvpn-pool name=VPN-dhcp src-address=10.1.2.1
add address-pool=dhcp_pool3 disabled=no interface=Wifi lease-time=1d10m name=\
"Wifi dhcp" src-address=192.168.100.1
add address-pool=dhcp_pool11 disabled=no interface=Vlan101-WifiGuest \
lease-time=2h10m name="WifiGuest dhcp"
add address-pool=dhcp_pool12 disabled=no interface=vlan10 lease-time=23h59m \
name=vlan10-dhcp
add address-pool=dhcp_pool13 disabled=no interface=vlan20 lease-time=23h59m \
name=vlan20-dhcp
add address-pool=dhcp_pool14 disabled=no interface=vlan30 lease-time=23h59m \
name=vlan30-dhcp
add address-pool=dhcp_pool15 disabled=no interface=vlan70 lease-time=23h59m \
name=vlan70-dhcp
add address-pool=dhcp_pool16 disabled=no interface=vlan80 lease-time=23h59m \
name=vlan80-dhcp
add address-pool=dhcp_pool17 disabled=no interface=vlan90 lease-time=23h59m \
name=vlan90-dhcp
add address-pool=dhcp_pool18 disabled=no interface=vlan100 lease-time=23h59m \
name=vlan100-dhcp
add address-pool=dhcp_pool19 disabled=no interface=vlan110 lease-time=23h59m \
name=vlan110-dhcp
add address-pool=dhcp_pool20 disabled=no interface=vlan120 lease-time=23h59m \
name=vlan120-dhcp
add address-pool=dhcp_pool21 disabled=no interface=vlan130 lease-time=23h59m \
name=vlan130-dhcp
add address-pool=dhcp_pool22 disabled=no interface=vlan140 lease-time=23h59m \
name=vlan140-dhcp
add address-pool=dhcp_pool23 disabled=no interface=vlan150 lease-time=23h59m \
name=vlan150-dhcp
add address-pool=dhcp_pool24 disabled=no interface=vlan160 lease-time=23h59m \
name=vlan160-dhcp
add address-pool=dhcp_pool25 disabled=no interface=vlan170 lease-time=23h59m \
name=vlan170-dhcp
add address-pool=dhcp_pool26 disabled=no interface=vlan40 lease-time=23h59m \
name=vlan40-dhcp
add address-pool=dhcp_pool27 disabled=no interface=vlan50 lease-time=23h59m \
name=vlan50-dhcp
add address-pool=dhcp_pool28 disabled=no interface=vlan60 lease-time=23h59m \
name=vlan60-dhcp
add address-pool=dhcp_pool29 disabled=no interface=vlan200 lease-time=23h59m \
name=vlan200-dhcp
/system logging action
add name=RemoteLog remote=10.1.1.250 target=remote
add bridge=bridge1 interface=ether11
/interface bridge vlan
add bridge=bridge1 tagged=Wifi vlan-ids=101
/interface ovpn-server server
set auth=sha1 certificate=Server cipher=aes256 default-profile=\
openvpn-profile enabled=yes require-client-certificate=yes
add address=10.1.1.1/24 comment="LAN bridge" interface=vlan1000 network=\
10.1.1.0
add address=192.168.101.1/24 comment="Gateway i Wifi per Guest" interface=\
Vlan101-WifiGuest network=192.168.101.0
add address=10.1.10.1/24 comment="VLAN 10 - Network" interface=vlan10 \
network=10.1.10.0
add address=10.1.20.1/24 comment="VLAN 20 - Network" interface=vlan20 \
network=10.1.20.0
add address=10.1.30.1/24 comment="VLAN 30 - Network" interface=vlan30 \
network=10.1.30.0
add address=10.1.40.1/24 comment="VLAN 40 - Network" interface=vlan40 \
network=10.1.40.0
add address=10.1.50.1/24 comment="VLAN 50 - Network" interface=vlan50 \
network=10.1.50.0
add address=10.1.60.1/24 comment="VLAN 60 - Network" interface=vlan60 \
network=10.1.60.0
add address=10.1.70.1/24 comment="VLAN 70 - Network" interface=vlan70 \
network=10.1.70.0
add address=10.1.80.1/24 comment="VLAN 80 - Network" interface=vlan80 \
network=10.1.80.0
add address=10.1.90.1/24 comment="VLAN 90 - Network" interface=vlan90 \
network=10.1.90.0
add address=10.1.100.1/24 comment="VLAN 100 - Network" interface=vlan100 \
network=10.1.100.0
add address=10.1.110.1/24 comment="VLAN 110 - Network" interface=vlan110 \
network=10.1.110.0
add address=10.1.120.1/24 comment="VLAN 120 - Network" interface=vlan120 \
network=10.1.120.0
add address=10.1.130.1/24 comment="VLAN 130 - Network" interface=vlan130 \
network=10.1.130.0
add address=10.1.140.1/24 comment="VLAN 140 - Network" interface=vlan140 \
network=10.1.140.0
add address=10.1.150.1/24 comment="VLAN 150 - Network" interface=vlan150 \
network=10.1.150.0
add address=10.1.160.1/24 comment="VLAN 160 - Network" interface=vlan160 \
network=10.1.160.0
add address=10.1.170.1/24 comment="VLAN 170 - Network" interface=vlan170 \
network=10.1.170.0
add address=10.1.200.1/24 comment="VLAN 200 - Network" interface=vlan200 \
network=10.1.200.0
add address=10.1.99.1/24 comment="VLAN 99 - Network" interface=vlan99 \
network=10.1.99.0
/ip dhcp-client
add add-default-route=no disabled=no interface="Telkos Ether2"
add interface="Kujtesa WAN - Ether4"
add address=10.1.1.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=10.1.1.1
add address=10.1.10.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.10.1
add address=10.1.20.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.20.1
add address=10.1.30.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.30.1
add address=10.1.40.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.40.1
add address=10.1.50.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.50.1
add address=10.1.60.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.60.1
add address=10.1.70.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.70.1
add address=10.1.80.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.80.1
add address=10.1.90.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.90.1
add address=10.1.100.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.100.1
add address=10.1.110.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.110.1
add address=10.1.120.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.120.1
add address=10.1.130.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.130.1
add address=10.1.140.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.140.1
add address=10.1.150.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.150.1
add address=10.1.160.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.160.1
add address=10.1.170.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.1.170.1
add address=10.1.200.0/24 dns-server=10.1.1.10,8.8.8.8,8.8.4.4 gateway=\
10.1.200.1
add address=192.168.100.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.100.1
add address=192.168.101.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.101.1
set servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=10.1.10.0/24 list=Vlan10-List
add address=10.1.20.0/24 list=Vlan20-List
add address=10.1.30.0/24 list=Vlan30-List
add address=10.1.10.0/24 list="All VLANs"
add address=10.1.1.0/24 list="IT Devices"
add address=10.1.200.0/24 list="IT Room"
add address=10.1.20.0/24 list="All VLANs"
add address=10.1.30.0/24 list="All VLANs"
add address=10.1.40.0/24 list="All VLANs"
add address=10.1.50.0/24 list="All VLANs"
add address=10.1.60.0/24 list="All VLANs"
add address=10.1.70.0/24 list="All VLANs"
add address=10.1.80.0/24 list="All VLANs"
add address=10.1.90.0/24 list="All VLANs"
add address=10.1.100.0/24 list="All VLANs"
add address=10.1.110.0/24 list="All VLANs"
add address=10.1.120.0/24 list="All VLANs"
add address=10.1.130.0/24 list="All VLANs"
add address=10.1.140.0/24 list="All VLANs"
add address=10.1.150.0/24 list="All VLANs"
add address=10.1.160.0/24 list="All VLANs"
add address=10.1.170.0/24 list="All VLANs"
add address=10.1.10.102 list="IT Room"
add address=10.1.10.107 list="IT Room"
add address=10.1.130.0/24 list=vlan130-List
add action=accept chain=forward comment="Permit connection with AD" \
dst-address=10.1.1.10 src-address-list="All VLANs"
add action=accept chain=forward comment="Permit connection with FilesServer" \
dst-address=10.1.1.19 src-address-list="All VLANs"
"Permit Recepsion with Camera connection" dst-address=10.1.1.222 \
src-address=10.1.170.101
"Permit IT Staff connection with IT devices" dst-address-list=\
"IT Devices" src-address-list="IT Room"
add action=accept chain=forward comment="Permit IP to communicate with IP" \
disabled=yes dst-address-list=Vlan20-List src-address=10.1.10.102
"Permit IT Staff Connection with All Vlans" disabled=yes \
dst-address-list="All VLANs" src-address-list="IT Room"
add action=drop chain=forward comment="Block an IP to access internet." \
disabled=yes src-address=10.1.1.79
disabled=yes src-address=10.1.20.108
disabled=yes src-address=10.1.1.63
disabled=yes src-address=10.1.10.105
add action=drop chain=forward comment="Blocking InterVLAN communication" \
dst-address-list="IT Devices" src-address-list="All VLANs"
dst-address-list="All VLANs" src-address-list="All VLANs"
"Blocking DS-VPN users from access internal resources. IN" disabled=yes \
dst-address=10.1.1.0/24 src-address=192.168.150.0/24
"Blocking DS-VPN users from access internal resources.OUT" disabled=yes \
dst-address=192.168.150.0/24 src-address=10.1.1.0/24
/ip firewall mangle
add action=accept chain=prerouting comment=\
"No rules apply for - 192.168.100.95" src-address=192.168.100.95
add action=mark-routing chain=prerouting comment="Wifi to ISP2 Rule" \
new-routing-mark="Wifi to ISP2" passthrough=yes src-address=\
192.168.100.0/24
192.168.101.0/24
add action=mark-routing chain=prerouting comment="PC te rrjeti i Telkosit" \
disabled=yes new-routing-mark="Wifi to ISP2" passthrough=yes src-address=\
10.1.10.102
add action=masquerade chain=srcnat comment="Default Route to Telkos" \
out-interface="Wan2 Ether2"
add action=masquerade chain=srcnat comment="Default Route to Kujtesa" \
out-interface=" WAN - Ether4"
add comment="Route using by Wifi " distance=2 gateway=192.168.1.1 \
add comment=Main distance=1 gateway=178.132.223.1
add comment=Backup distance=2 gateway=192.168.1.1
add check-gateway=ping comment="Netwatch Main" disabled=yes distance=2 \
dst-address=8.8.4.4/32 gateway=178.132.223.1
add check-gateway=ping comment="Netwatch Backup" disabled=yes distance=1 \
dst-address=8.8.8.8/32 gateway=192.168.1.1
add comment="Static route for Wifi - 1" disabled=yes distance=1 dst-address=\
192.168.100.0/24 gateway=10.10.10.2
add comment="Static route for Wifi - 2" disabled=yes distance=1 dst-address=\
192.168.200.0/24 gateway=10.10.10.2
Thank you in advance guys. I would appreciate your help.
