Firewall rule to block all connection except to VPN server
As the title says I need to block all the connection to mikrotik router from outside except connection to VPN server. Then allow Remote desktop to LAN’s system over VPN(either L2TP/IPSec or PPTP) from outside LAN.
What would be the rule in Mikrotik router’s Firewall to block all the connection except rdp over vpn?
Addition infor:
There is LAN setup in our office and the final gateway is Mikrotik router.
I know how to create VPN server, VPN client in clients system and make rdp from clients system.
I want that external firewall should only let in connections to VPN server.
For L2TP UDP ports 500 and 4500 and protocol ipsec-esp
For PPTP TCP port 1723 and protocol gre
http://blogs.technet.com/b/rrasblog/archive/2006/06/14/which-ports-to-unblock-for-vpn-traffic-to-pass-through.aspx
Once VPN tunnels are established clients will have access to RDP. Now if you want to filter on established VPN tunnels then you need to create a firewall rule that will drop packets with a source IP of your VPN clients assigned by your VPN server. DHCP pool for office 192.168.88.100-192.168.88.199, pool for VPN 192.168.88.200-192.168.88.209.
ip firewall filter add chain=forward action=drop protocol=tcp src-address=192.168.88.200-192.168.88.209 dst-address=192.168.88.0/24 dst-port=!3389
