Firewall rule to block router input traffic on WIRELESS interfaces
I would like to block all input traffic to my router on all wireless interfaces except for 1 ip address with a specific mac address.
I made this rule but it is not working no matter where I place it on the firewall table
 0    ;;; Blocking unauthorized LAN Router access
      chain=input action=drop protocol=tcp src-address=!192.168.88.251 src-address-list=""
      in-interface=all-wireless src-mac-address=!BE:19:AA:C2:FE:9E log=no log-prefix=""
The rule seems pretty straight forward but as I am a beginner I cant see where I am mistaking.
Unset / remove property src-address-list … setting it to empty string is not the same as not setting it at all.
Setting in-interface=all-wireless is problematic as well, for two reasons:
  • using automatic interface lists has a few quirks and it’s better to use interface names explicitly
  • it only works if wireless interfaces are not made bridge ports. If wireless interfaces are in fact bridge pirts, then firewall will see bridge interface as in-interface
Setting protocol=tcp means tgat this rule will not trigger on any other protocols, i.e. all remote hosts will be able to connect to router using e.g. UDP.
