Firewall rule with no protocol specified ?
If I have a rule specif like this:
7 X chain=fwd_from_INET dst-address=10.5.254.11 protocol=tcp dst-port=80 action=accept
8 X chain=fwd_from_INET dst-address=10.5.254.11 dst-port=80 action=accept
9 chain=fwd_from_INET dst-address=10.5.254.11 dst-port=112 action=drop
when I enable 7, it hos no influence on rule 9, but if I enable 8, rule 9 is ignored, all traffic goes to tcp 10.5.254.11:112 without problems
Why is that? rule 8 without protocol specification passws through much more than port 112?
Ports only have any meaning when you specify either TCP or UDP. Your rules 8 & 9 are illegal. You have to specify a protocol if you intend to specify a port.
Regards
Andrew
you have to set protocol if you want to use dst-port
