Dear Sir
I want to block an IP on BTS so that from client side it will not be ping-able.
what i am doing is
0 chain=forward action=reject reject-with=icmp-admin-prohibited protocol=tcp dst-address=“”
Dear Sir
what i am doing is
If you want to block pings set protocol=icmp
in your case you are blocking all tcp connections
Actually sir i want to block some websties on my bts so that they should not open at client side.
and also want to block certain ip’s which will hitting my client or bts .
Awating response.
if you’re using a transpartent proxy in the MT Router, you can use proxy to block websites.
to use firewall to block a certain ip, I suggest doing the following:
[router] /ip firewall address-list> add address=1.1.1.1/32 list=aaa
[router] /ip firewall filter> add address-list=aaa action=drop chain=forward
Dear Sir
Thanks for quick response
Actually i want to stop http traffic without using any proxy and i am using RB1000 as my Default router and also let me know what enable tracking in firewall connection and where it is used.
