i have a p2p firewall rule set up like this
add chain=forward p2p=all-p2p time=7h30m-22h00m,sat,fri,thu,wed,tue,mon,sun
action=drop comment=“” disabled=no
it works fine.
I want to make it so that the rule only applys to certin ip ranges, so i added this:
add chain=forward src-address=10.10.54.0/24 p2p=all-p2p
time=7h30m-23h55m,sat,fri,thu,wed,tue,mon,sun action=drop comment=“”
disabled=no
I was hoping this would make it so anyone with a 10.10.54.* address would have limited p2p access between 7:30am and 10pm.
Help please.
janisk
August 2, 2006, 1:43pm
2
it loogs ok, jsut add another rule to do same for dst-address too so all packets are going to be dropped.
ok ive updated the rule but p2p still gets through. With the src and dst addresses removed the rule works fine.
chain=forward src-address=10.10.54.0/24 dst-address=10.10.54.0/24
p2p=all-p2p time=7h30m-22h,sat,fri,thu,wed,tue,mon,sun action=drop
hi , tried that rule … it works fine…
but if the p2p client is already connected it dosnt drop the connection…
any clues!?
sten
October 18, 2006, 10:53pm
6
because p2p matching only happens once (somewhere around the beginning of a connection). all-p2p only matches to a single packet in a given connection.
instead mark p2p traffic in mangle forward with a connection mark and then change the filter rule to drop packets belonging to that connection-mark.
Djeeze
ok ive set up the connection mark:
chain=forward p2p=all-p2p action=mark-connection new-connection-mark=p2p-conn-drop passthrough=yes
and then the firewall rule:
;;; p-2-p Control
connection-mark=p2p-conn-drop p2p=all-p2p action=drop
The idea once again was to stop any customer whos address is in the 10.10.54.* pool
what am i missing??
It should be like this:
/ ip firewall mangle add action=mark-connection chain=prerouting new-connection-mark=p2p_connection p2p=all-p2p passthrough=yes
/ ip firewall mangle add action=mark-packet chain=prerouting connection-mark=p2p_connection new-packet-mark=p2p_packet passthrough=yes
/ ip firewall filter add action=drop chain=forward packet-mark=p2p_packet
In addition to what macgaiver said, You need to have two separate rule to drop P2P for this to work. i.e.
/ ip firewall filter add chain=forward src-address=10.10.54.0/24 packet-mark=p2p_packet p2p=all-p2p action=drop
/ ip firewall filter add chain=forward dst-address=10.10.54.0/24 packet-mark=p2p_packet p2p=all-p2p action=drop
Just replace the last rule in Macgaiver’s post with these two rules.
janisk
November 16, 2006, 10:03am
10
strange it seems p2p programs has been updated
Thanks for the help guys.
Mac’s part works like a trick, i can see the counters for both packet and connection mark working and counting together. cheers
Skillful, the rule does not seem to stop the 10.10.54.0 subnet? does the rules have to be on the wireless MT? i have one as my gateway, the other as my AP i have put the rules on the gateway not the AP?
Cheers
Jrslick22, the rules have been modified slightly as follows:
/ ip firewall filter add chain=forward src-address=10.10.54.0/24 packet-mark=p2p_packet action=drop
/ ip firewall filter add chain=forward dst-address=10.10.54.0/24 packet-mark=p2p_packet action=drop
Put these rules on the MT closest to the source IP. It works for me.
jose
December 2, 2006, 4:14pm
13
What would happen if I just put
/ip firewall filter add chain=forward p2p=all-p2p action=drop ?
