Firewall Rules - Access blocked after successful connection
Hi all,
Thanks for accepting me into the community. I am a Linux novice and although I have used the RB951 for nearly 2 years I’m afraid I do still use Winbox for configuration as my SSH skills are far from perfect!
I have a strange problem that I haven’t seen before. My firewall rules are all working and I use the RB951 on our large scale solar farms to connect our monitoring systems to the satellite broadband on site. We use a number of data loggers which communicate with a web portal.
I have firewall rules to access port 80 of the data loggers for configuration and basically use xxx.xxx.xxx.xxx:8021 to 192.168.1.101:80
The rule works fine and I can browse to the device and login, however, when attempting to browse to any of the data logger menus I just get a “Page could not be displayed” and then I can no longer access the data logger, even with a reboot of the RB951. Could there be some dynamic port changing going on behind the scenes that is denying access?
Many thanks in advance,
Bret
Does anyone have any ideas regarding this problem? It is still an issue. Mikrotik support maybe?
Thanks,
Bret
It sounds to me like the device’s page has hard-coded IP addressing in the links.
Mouse-over a link and watch what the URL is before clicking on it.
The only way around that is going to be unique addressing everywhere, and no-nat VPN into each site.
Do the devices have snmp support?
What about setting up a VPN server on the MikroTik? Then you could be on the local network remotely.
Use MikroTIk VPN to access your mikrotik. Then only NAT-ing the port (avoid to set port 80 as internal port) and will be ok.
