i would like your advices about my firewall filter rules.
i’m a noob, I have build my rules following several tutorials and mikrotik manual.
I think understanding more or less the job of them, but less about the importance of the ordering of them, especially wireguard rules, fasttrack rules and ssh protecting rules.
I have also a problem for setup wireguard: client can access to lan but can’t access internet.
Here my firewall rules, could you said me your opinion about them and the necessary changes for optmize them?
Thank you
add action=add-src-to-address-list address-list=Syn_Flooder address-list-timeout=30m chain=input comment="Add Syn Flood IP to the list" connection-limit=30,32 protocol=tcp tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner address-list-timeout=1w chain=input comment="Port Scanner Detect" protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=ICMP protocol=icmp
add action=drop chain=input comment="Block all access to the winbox - except to support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT ADDRESS LIST" dst-port=8291 protocol=tcp src-address-list=!support
add action=jump chain=forward comment="Jump for icmp forward flow" jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=bogons
add action=add-src-to-address-list address-list=spammers address-list-timeout=3h chain=forward comment="Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=25,587 limit=30/1m,0:packet log=yes protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 log=yes protocol=tcp src-address-list=spammers
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="allow wireguard" dst-port=13231 protocol=udp
add action=accept chain=forward comment="Allow wireguard traffic to lan" dst-address=10.28.201.0/24 src-address=10.13.13.0/24
add action=accept chain=forward comment="Allow wireguard traffic to internet" dst-address=0.0.0.0/24 src-address=10.13.13.0/24
add action=fasttrack-connection chain=forward comment=Fasttrack connection-state=established,related disabled=yes hw-offload=yes
add action=accept chain=forward comment=Fasttrack connection-state=established,related disabled=yes
add action=accept chain=input comment="Accept to established connections" connection-state=established
add action=accept chain=input comment="Accept to related connections" connection-state=related
add action=accept chain=input comment="Full access to SUPPORT address list" src-address-list=support
add action=accept chain=input comment="Allow IGMP for Orange TV" in-interface=vlan840-TV-Stream protocol=igmp
add action=accept chain=output comment="Allow IGMP for Orange TV" out-interface=vlan840-TV-Stream protocol=igmp
add action=accept chain=input comment="Allow IGMP for Orange TV" in-interface=ether7-TV protocol=igmp
add action=accept chain=forward comment="Allow Forward Multicast Orange" dst-address=224.0.0.0/4 dst-port=8200,8202 in-interface=vlan840-TV-Stream protocol=udp
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 log=yes log-prefix=dropssh_ protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=1w3d chain=input connection-state=new dst-port=22 log=yes log-prefix=dropssh_ protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=22 log=yes log-prefix=dropssh_ protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=22 log=yes log-prefix=dropssh_ protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=22 log=yes log-prefix=dropssh_ protocol=tcp
add action=drop chain=forward comment="drop ssh brute downstream" dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=drop chain=input comment="BLOQUE TOUTES LES CONNEXIONS ENTRANTES (exception avant)"
add action=accept chain=ICMP comment="Echo request - Avoiding Ping Flood" icmp-options=8:0 limit=1,5:packet protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP protocol=icmp
