Firewall Rules: Block ICMP from WAN (PPPOE connection)
Dear members,
I’m having problems blocking ICMP (echo-reply) packets from WAN. Below are my firewall filters for your reference, the one which I specifically did is rule #5.
[admin@MikroTik] /ip firewall filter> print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=“”
2 ;;; defconf: accept established,related
chain=forward action=accept connection-state=established,related log=no log-prefix=“”
3 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=“”
4 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1 log=no log-prefix=“”
5 chain=input action=drop protocol=icmp in-interface=ether1 icmp-options=8:0 log=no log-prefix=“”
6 chain=input action=accept protocol=icmp log=no log-prefix=“”
7 chain=input action=accept connection-state=established log=no log-prefix=“”
8 chain=input action=accept connection-state=related log=no log-prefix=“”
9 chain=input action=drop in-interface=pppoe-out1 log=no log-prefix=“”
Thanks in advance, your help is highly appreciated.
Best regards,
FoxJr
Why you choose in-interface as ether1 instead of pppoe-out1?
I tried both to be honest, and same result. Also ether1 is the interface handling my internet connection, therefore it should work anyway.
5 chain=input action=drop protocol=icmp in-interface=pppoe-out1 icmp-options=8:0 log=no log-prefix=“”
The rule is correct right?
Regards,
FoxJr
Ether1 in your case is merely physical interface carrying packets encapsulated into PPPoE. Your wan interface is pppoe-out1 and you should use that interface in FW rules that protect your router from evil internet.
As to firewall: you’re blocking echo-reply … meaning that if you use ping tool on your router to ping some WAN host, your FW will drop reply. What you probably want is to block echo(-request), which, according to RFC792, is icmp-options=8:8 …
I performed the actions suggested, however still no luck.
chain=input action=drop protocol=icmp in-interface=pppoe-out1 icmp-options=8:8 log=no log-prefix=“”
If i ping my public IP from an external source, it still replies.
This should be relatively easy.
In my default setup I have this rule.
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
I am assuming the input accept rule is there because otherwise the incoming traffic will be dropped by
one of the following rules…
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
I suppose one could add in a specific rule to drop but is probably no needed.
In which case take the same rule and simply change this to drop!! and place it at after all the accept rules for input.
Chain= input
protocol= 1 (ICMP)
action= drop
The question I have is why not put it as an IP RAW rule in prerouting???
and thus it will be removed before getting any kind of connection.
Thanks for the suggestion anav, if im mistaken already did this with no success but will have a look again.
As for this being easy, i totally agree with you but for some strange reason its not working. Ichecked various tutorials and all suggested the same rule i implemented however ping request are still being answered.
Anyway, will test again and revert back.
Regards,
FoxJr
I am just curious why you want to block ping?
Anyway if you insist on it start with simple input icmp drop rule placed somewhere on top. If this works then do fine tuning in more detail.
If this does not work then you are actually pinging different device (you modem - as you wrote that your WAN is ether1). Therefore switch your modem to bridge and create PPPoE client in Mikrotik. And be careful /clever with firewall rules (your WAN will be pppoe1 now!)
Try 8:0 echo request on input chain and 0:0 echo reply on output chain
Why?
If there is a default rule to allow ICMP on the input chain. Removing the rule should be all that is required.
If there is need to block ICMP, why not do it in IP RAW in prerouting.
Nobody is listening LOL.
Good evening lads,
Here are my replies;
@Pea: I want to disable ICMP from WAN for security reasons. I know there are other ways one can identify if there is something active on a particular public IP but I would like to minimize this as possible.
@CZFan: I will try your suggestion and revert back, however, the strange thing is that I disabled all those rules listed in the attached file, yet my public IP still replies from outside.
@anav: Could you please guide me how to block implement via suggested IP RAW prerouting?
As always thanks again for your contribution!
Regards,
FoxJr
Maybe you have a rule in IP firewall raw that is accepting it as that will happen before filter rules.
If not, then best you post export of following here so we have all info to assist.
/ip firewall filter export
/ip firewall nat export
/ip firewall raw export
Hi FoxJr,
I just tested my Filter Rules from default.
I had the allow ICMP rule in there…
I checked my ports via www.grc.com and the shieldsUP tests.
I failed as the ICMP replies occurred from my router.
I removed the rule and I passed the test
Your system ignored and refused to reply to repeated Pings (ICMP Echo Requests)
So I disagree with your findings!
The default Filter rules already block ICMP, I had to put in an allow rule to make myself visible.
“defconf: accept established,related,untracked” connection-state=
invalid
Although I dont have any output rules and forward chains should not affect wan responses I put them here just in case…
add action=drop chain=forward comment=“defconf: drop invalid”
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
Finally If I was to make a raw rule, which I don’t think is necessary it would look something like
/ip firewall raw
add action=drop chain=prerouting protocol=icmp comment=Stop_Ping in-interface ISPname OR (in-interface list WAN if you have dual ISP, wan1 and wan2)
Rules 5 and 6 should not exist in your configuration, especially if your WAN is your Internet connection.
Remove these entirely:
5 chain=input action=drop protocol=icmp in-interface=ether1 icmp-options=8:0 log=no log-prefix=""
6 chain=input action=accept protocol=icmp log=no log-prefix=""
You need nothing else and you are overthinking this.
Hey guys, thanks for your feedback. Unfortunately, I had no time to review or test any suggestions due to busy schedule. Will do this in the following days and revert back with results.
Regards,
FoxJr
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=
new in-interface=ether1
add action=drop chain=input disabled=yes icmp-options=8:8 in-interface=pppoe-out1 log=yes protocol=icmp
add action=accept chain=input disabled=yes protocol=icmp
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=pppoe-out1
add action=drop chain=forward comment="OnePlus X - No Internet" disabled=yes src-address=192.168.2.115
inactive time
add action=drop chain=forward comment="Samsung Galaxy S4 Mini - No Internet" src-address=192.168.2.104 time=
21h30m-6h30m,sun,mon,tue,wed,thu,fri,sat
[admin@MikroTik] > /ip firewall nat export
may/07/2018 20:12:58 by RouterOS 6.42.1
software id = DN4Z-H0I3
model = RouterBOARD 750G r2
serial number =
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=pppoe-out1
add action=dst-nat chain=dstnat comment="UVNC Client" dst-address=<public_ip> dst-port=6000 protocol=tcp to-addresses=
192.168.2.105 to-ports=6000
add action=dst-nat chain=dstnat dst-address=<public_ip> dst-port=6001 protocol=tcp to-addresses=192.168.2.100 to-ports=6001
add action=dst-nat chain=dstnat comment="QNAP NAS" dst-address=<public_ip> dst-port=6002 log=yes protocol=tcp to-addresses=
192.168.2.110 to-ports=443
add action=dst-nat chain=dstnat comment=FTP disabled=yes dst-address=<public_ip> dst-port=21 protocol=tcp to-addresses=
192.168.2.110 to-ports=21
add action=dst-nat chain=dstnat disabled=yes dst-address=<public_ip> dst-port=20 protocol=tcp to-addresses=192.168.2.110
to-ports=20
add action=dst-nat chain=dstnat comment=UTorrent dst-address=<public_ip> dst-port=38862 protocol=tcp to-addresses=
192.168.2.105 to-ports=38862
add action=dst-nat chain=dstnat comment=RDP disabled=yes dst-address=<public_ip> dst-port=7000 protocol=tcp to-addresses=
192.168.2.112 to-ports=3389
add action=dst-nat chain=dstnat comment=DMZ in-interface=pppoe-out1 to-addresses=192.168.2.109
[admin@MikroTik] > /ip firewall raw export
may/07/2018 20:13:22 by RouterOS 6.42.1
serial number =
[admin@MikroTik] >
Are you sure it is not maybe your device 192.1682.109 responding to pings, see last rule in ip firewall nat, you are forwarding everything coming in on PPPoE to that device
Change this “add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=
new in-interface=ether1” on pppoe-out1 in in-interface, please.
The device in question is a PlayStation 4, I will try to turn off the system completely and test again.
Peformed this as requested;
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=pppoe-out1 log=no log-prefix=“”
No luck, still able to ping from an external source.
