Firewall rules execution speed question
I was just wondering if it maxes the overall execution of firewall rules quicker if I place logically connected rules in different chains?
I mean that way the 4-5 rules connected together get executed only if the JUMP rule in the main chain is matched. But the jump could cause equally high load.
So is it a good practice to use separate chains?
Thank you!
Bests,
Semir
if packet passes only few of your rules, it makes lower load. so if you jump to subchains only in rare cases - it’s better than the same rules in main chain
Thought so.
Thank you :slight_smile:
