Firewall Rules in backup
I need to add few rules to my ip firewall whtch contain: first ip address from wlan1.
example:
need to do dst-nat for one of the ip
add action=dst-nat chain=dstnat disabled=no dst-address=172.16.190.10 dst-port=
!8291 protocol=tcp to-addresses=192.168.1.50
!8291 protocol=udp to-addresses=192.168.1.50
[admin@MikroTik] > ip address print
ADDRESS NETWORK INTERFACE
0 192.168.100.252/24 192.168.100.0 ether1
1 172.16.190.10/24 172.16.190.0 wlan1
ip address get value-name=address number=1
#no answer :frowning:
huh?
huh?[/quote]
I edited the post. My problem was quite simple.
The solution:
:put [/ip address get value-name=address number=0]
But there is next problem:
Is it possible to add a rule with other type of ip address declaration?
(when I change an ip, the rule will be also changed?)
You could use the in-interface option instead.
 ip firewall nat set to-addresses=[/ip address get value-name=address number=0] [/ip firewall nat find comment=redirect]
