Firewall tables
Hi
[newbie] I have been looking at firewall section, am I am trying to build some chains, basically using my linux skills and translating across. I was wonder if it would not be possible to create directories below / ip firewall filter to each of the chains the default ones and the user created ones.
benefit, well if you have 20 or 30 or … lines in and multiples chains it all gets a bit muddled up when yo do a print, yes I know about the print chain=, haven’t yet figured out the print where syntax yet.
seems like alot of the other interfaces let you do that ..
Thanks.
