firewall + webproxy
hi all,
i have mikrotik transparent proxy at ip x.x.x.x ( public ) now work well, then at other mikrotik gateway y.y.y.y want used proxy at x.x.x.x
if both mikrotik at same segmen IP, at gateway i just mangle port 80 traffic then i add default route to x.x.x.x for port 80 and work. but when other mikrotik ( different segmen IP with proxy ) want used that proxy, what rule for it ? thanks for sharing
on other segment IP network - make correct routing so that both networks can reach other and same rule for other router
