Firewall
I saw video about firewall, where it says, that it is not recommended to open firewall even from specific public IP to the router. If this IP is my trusted network, why shouldn’t i do that? It could be spoofed or somehow bypassed in another way?
Personally allowing access to a device on Internet through a “whitelisted” source-IP(s) is acceptable to me and we do that for customers across our projects.
VPN is not always an option or sometimes overkill.
Just make sure you have additional layers like (encrypted) authentication using complex logins (both username & password) and make your have logging + notification enabled.
And additionally LIMIT the exposure off course, filter only the ports that are needed!
The attack-vector with a construction like this is pretty low. A “zero-risk” does not exist, not for any solution.
How these attacks are called? I would read more about them.
Attack-vector? Or spoofing?
Disagree with JV, the clue here he is a well trained person knowing what he is doing, and giving such flippant advice to a beginner is both dangerous and foolish.
The only method you should consider connecting to your router for the purposes of accessing LAN resources or more likely to be able to config the router is through VPN and wireguard is part of RoS and fairly easier compared to other VPN methods. Highly recommended.
Another common method to access servers on your LAN is port forwarding and here ensure
a. the server is password protected 2 factor best
b. you limit users by source address
instead of port forwarding.
… if it all possible use ZeroTrust Cloudflare tunnel in a container ( sadly although highly needed, MT has elected not to make this available as part of OS like wireguard, but not even an options package, shame on them ).
