Firewall
My MikroTik router has two (2) LAN Cards support two seperate Netoworks. I want to be able to access computers on LAN2 network from LAN1 network. How can go about achieving this. Thank you.
with no firewall rules, and default routes on the clients pointing to the IPs of the RB, the traffic will just pass !
So which firewall rule might be blocking access to LAN2 from LAN2. Thanks
It would help to see your rules. “/ip firewall filter print all” and “/ip firewall nat print all”
Feel free to change any public ips for security reasons.
Attached is the Firewall screenshots.
All rules have being disadbled, still, I can’t access the 2 networks from each orther. tnx
please use software like JING or Zscreen to make screenshots, i had to delete yours due to their enormous size.
eNormis size? I hope someone else sees the humor in this!
@normis: you are by far my favorite tech support guy. It is not meant as a run-down, only as a friendly poke!
:smiley:
no but seriously, that screenshot was some 4000px wide, oversampled.
