Firmware change from INT to US ver. into WAP LTE modem
We recently purchase 5 x WAP LTE RBwapr-2nd&r11e-LTE international version in a store outside my country
I’m from Bolivia, and after I installed, I noticed the mobile conexion are too slow, at 3G HSDPA,
after asking to mobile provider, they said the RB is not correctly configured for work in LTE network.
But after checking documentation, we noticed the US version is for LATIN countries,
contrary to WIFI models hardware.
Apreciate we can have the procedure to change firmware from INT version to US version,
or enable LTE bands for latinamerica countris at out modem.
Apreciate your help.
Some details of versions
RB stable 6.48.4
/interface lte info lte1 once
pin-status: ok
registration-status: registered
functionality: full
manufacturer: “MikroTik”
model: “R11e-LTE”
revision: “MikroTik_CP_2.160.000_v018”
current-operator: Cuidemonos. Vacunate.
psc: 34
lac: 17527
current-cellid: 3303863
access-technology: 3G HSDPA
session-uptime: 10h59m3s
imei: 355654092210355
imsi: 736030058401529
uicc: 8959103000584015296f
earfcn: 4357
rssi: -79dBm
regards
gustavo
The problem is not with firmware, the problem is physical - support for different frequency bands.
R11e-LTE (international) supports: 1 (2100MHz) / 2 (1900MHz) / 3 (1800MHz) / 7 (2600MHz) / 8 (900 MHz) / 20 (800MHz) / 38 (2600MHz) / 40 (2300MHz)
(the last two are TDD bands)
R11e-LTE-US supports: 2 (1900MHz) / 4 (1700MHz) / 5 (850MHz) / 12 (700MHz)
You can replace LTE modem. You might want to use R11e-LTE6, which is both faster (cat6 up to 300Mbps compared to cat4 up to 150Mbps) and supports greater number of frequency bands: 1 (2100MHz) / 2 (1900MHz) / 3 (1800MHz) / 7 (2600MHz) / 8 (900 MHz) / 20 (800MHz) / 5 (850MHz) / 12 (700MHz) / 17 (700MHz) / 25 (1900MHz) / 26 (850MHz) and TDD bands 38 (2600MHz) / 40 (2300MHz) / 39 (1900MHz) / 41n (2500MHz)
But then it really depends on which frequency bands are used by your MNO.
HI,
Apreciate your feedback.
What a big problem, not have the same modem for all bands available.
regards for your coment
