ne30n2
July 21, 2017, 6:26am
1
I’m currently have CCR1009 which I have already upgraded to latest stable version 6.39.2. I am experiencing issue with iOS device not automatically showing up login page.
What I have tried after researching are 1) Use walled gargen 2) change DNS name to external. None of this work for me. So I guess this is due to Mikrotik firmware version. I believe that this is the case because I also have another mikrotik with version 6.35 it doesn’t have issue with ios login page at all with same setting.
Therefore I tried to downgrade from 6.39.2 to 6.35 but without success. I can only downgrade to version 6.38.5 which is the Factory firmware version, but not version lower than this.
So I really need you suggestion how to downgrade to lower version.
Thx
Nick
ne30n2
July 21, 2017, 8:39am
2
Please note that after trying to downgrade. The log show an error: omitting package system-6.35: min RouterOS version is 6.38.5
normis
July 21, 2017, 8:43am
3
How about trying to resolve the issue instead?
Have you contacted MikroTik support about this?
We have no other reports about iOS and hotspot on the latest versions. Maybe you have a mistake in the config and version has nothing to do with the issue?
We tested iOS 10 and iOS 11 beta and detected no hotspot login popup problems with RouterOS 6.40 RC
ne30n2
July 21, 2017, 11:09am
4
Oh well Normis, please help to advice if I have any mistake config this.
Here is my code. I would love professional person to help looking at my config. I am a newbie myself.
#RouterOS 6.39.2
add arp=reply-only comment="bridge1: ether 4-5 as HOTSPOT" name=bridge1
add arp=reply-only comment="bridge2: ether 6-7 as LAN" name=bridge2
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-WAN
set [ find default-name=ether3 ] name=ether3-WAN
set [ find default-name=ether4 ] name=ether4-HOTSPOT
set [ find default-name=ether5 ] name=ether5-HOTSPOT
set [ find default-name=ether6 ] name=ether6-LAN
set [ find default-name=ether7 ] name=ether7-LAN
/ip firewall layer7-protocol
add name=layer7-bittorrent-exp regexp="^(\\x13bittorrent protocol|azver\\x01\$\
|get /scrape\\\?info_hash=get /announce\\\?info_hash=|get /client/bitcomet\
/|GET /data\\\?fid=)|d1:ad2:id20:|\\x08'7P\\)[RP]"
/ip hotspot profile
add dns-name=wifi.com hotspot-address=10.10.10.1 login-by=\
http-chap,mac-cookie name=HOTSPOT use-radius=yes
/ip hotspot
add disabled=no idle-timeout=4h interface=bridge1 name=hotspot1 profile=\
HOTSPOT
/ip hotspot user profile
add !idle-timeout keepalive-timeout=1d name=unlimited_user shared-users=\
unlimited transparent-proxy=yes
add !idle-timeout keepalive-timeout=1d name=shared1user shared-users=1 transparent-proxy=yes
add name=pool_HOTSPOT ranges=10.10.10.2-10.10.10.254
add name=pool_LAN ranges=10.10.20.2-10.10.20.254
add add-arp=yes address-pool=pool_HOTSPOT authoritative=after-2sec-delay \
disabled=no interface=bridge1 lease-time=1d name=HOTSPOT_dhcp
add add-arp=yes address-pool=pool_LAN authoritative=after-2sec-delay disabled=no \
interface=bridge2 lease-time=4h name=LAN_dhcp
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw password=\
XXX time-zone=+07:00
/tool user-manager profile
add name=30day_shared1 name-for-users="" override-shared-users=1 owner=\
admin starts-at=logon validity=4w2d
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name=shared1user ip-pool="" name=\
shared1user owner=admin transfer-limit=0B upload-limit=0B uptime-limit=0s
add bridge=bridge1 interface=ether4-HOTSPOT
add bridge=bridge1 interface=ether5-HOTSPOT
add bridge=bridge2 interface=ether6-LAN
add bridge=bridge2 interface=ether7-LAN
add address=192.168.10.2/24 comment="WAN: ether1" interface=ether1-WAN \
network=192.168.10.0
add address=192.168.20.2/24 comment="WAN: ether2" interface=ether2-WAN \
network=192.168.20.0
add address=192.168.30.2/24 comment="WAN: ether3" interface=ether3-WAN \
network=192.168.30.0
add address=10.10.10.1/24 comment="HOTSPOT: bridge ether4-5" interface=\
bridge1 network=10.10.10.0
add address=10.10.20.1/24 comment="LAN: bridge ether 6-7" interface=bridge2 \
network=10.10.20.0
add address=10.0.10.1/24 comment="Access point IP to HOTSPOT" interface=\
bridge1 network=10.0.10.0
add address=10.0.20.1/24 comment="Access point IP to LAN" interface=bridge2 \
network=10.0.20.0
add address=10.10.10.0/24 comment="HOTSPOT pool" dns-server=10.10.10.1 \
gateway=10.10.10.1
add address=10.10.20.0/24 comment="LAN pool" dns-server=10.10.20.1 gateway=\
10.10.20.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=192.168.20.0/24 comment="WAN1: 192.168.20.0/24" list=WAN2
add address=192.168.30.0/24 comment="WAN1: 192.168.30.0/24" list=WAN3
add address=192.168.10.0/24 comment="WAN1: 192.168.10.0/24" list=WAN1
add address=10.10.10.0/24 comment="HOTSPOT: 10.10.10.0/24" list=LAN_HOTSPOT
add address=10.10.20.0/24 comment="LAN: 10.10.20.0/24" list=LAN_HOTSPOT
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=add-src-to-address-list address-list=bit-list \
address-list-timeout=1m chain=forward comment="Block Bittorrent" \
dst-address-list=!bit-unblock-list layer7-protocol=layer7-bittorrent-exp \
src-address-list=!bit-unblock-list
address-list-timeout=1m chain=forward dst-address-list=!bit-unblock-list \
layer7-protocol=layer7-bittorrent-exp src-address-list=!bit-unblock-list \
src-address-type=local
add action=drop chain=forward dst-port=!80,443 protocol=tcp src-address-list=\
bit-list
add action=drop chain=forward protocol=udp src-address-list=bit-list
/ip firewall mangle
add action=accept chain=prerouting dst-address-list=WAN1
add action=accept chain=prerouting dst-address-list=WAN2
add action=accept chain=prerouting dst-address-list=WAN3
add action=accept chain=prerouting disabled=yes dst-address-list=LAN_HOTSPOT
add action=mark-connection chain=input comment="INPUT: mark connection" \
connection-mark=no-mark in-interface=ether1-WAN new-connection-mark=\
WAN1_conn passthrough=yes
add action=mark-connection chain=input connection-mark=no-mark in-interface=\
ether2-WAN new-connection-mark=WAN2_conn passthrough=yes
ether3-WAN new-connection-mark=WAN3_conn passthrough=yes
add action=mark-routing chain=output comment="OUTPUT: mark connection" \
connection-mark=WAN1_conn new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_conn \
new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN3_conn \
new-routing-mark=to_WAN3 passthrough=yes
add action=mark-connection chain=prerouting comment=\
"PPC HOTSPOT: WAN1 (200Mbs) + WAN2 (200Mbs) + WAN3 (50Mbs)" \
connection-mark=no-mark dst-address-type=!local hotspot=auth \
in-interface=bridge1 new-connection-mark=WAN1_conn passthrough=yes \
per-connection-classifier=both-addresses:9/0
add action=mark-connection chain=prerouting connection-mark=no-mark \
dst-address-type=!local hotspot=auth in-interface=bridge1 \
new-connection-mark=WAN1_conn passthrough=yes per-connection-classifier=\
both-addresses:9/1
both-addresses:9/2
both-addresses:9/3
new-connection-mark=WAN2_conn passthrough=yes per-connection-classifier=\
both-addresses:9/4
both-addresses:9/5
both-addresses:9/6
both-addresses:9/7
new-connection-mark=WAN3_conn passthrough=yes per-connection-classifier=\
both-addresses:9/8
"PPC LAN: WAN1 (200Mbs) + WAN2 (200Mbs) + WAN3 (50Mbs)" connection-mark=\
no-mark dst-address-type=!local in-interface=bridge2 new-connection-mark=\
WAN1_conn passthrough=yes per-connection-classifier=both-addresses:9/0
WAN1_conn passthrough=yes per-connection-classifier=both-addresses:9/1
WAN1_conn passthrough=yes per-connection-classifier=both-addresses:9/2
WAN1_conn passthrough=yes per-connection-classifier=both-addresses:9/3
WAN2_conn passthrough=yes per-connection-classifier=both-addresses:9/4
WAN2_conn passthrough=yes per-connection-classifier=both-addresses:9/5
WAN2_conn passthrough=yes per-connection-classifier=both-addresses:9/6
WAN2_conn passthrough=yes per-connection-classifier=both-addresses:9/7
WAN3_conn passthrough=yes per-connection-classifier=both-addresses:9/8
add action=mark-routing chain=prerouting comment=\
"Mark packets from each connection to to proper routes " connection-mark=\
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
add action=mark-routing chain=prerouting connection-mark=WAN3_conn \
add action=masquerade chain=srcnat comment=\
"NAT to make local IP to be able to go to extranet" out-interface=\
ether1-WAN
add action=masquerade chain=srcnat out-interface=ether2-WAN
add action=masquerade chain=srcnat out-interface=ether3-WAN
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=10.10.10.0/24
/ip hotspot walled-garden
add dst-host=:^www.apple.com
add dst-host=:^www.airport.us
add dst-host=:^www.itools.info
add dst-host=:^www.appleiphonecell.com
add dst-host=:^captive.apple.com
add dst-host=:^www.thinkdifferent.us
add dst-host=:^www.ibook.info
add check-gateway=ping distance=1 gateway=192.168.10.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.20.1 routing-mark=to_WAN2
add check-gateway=ping distance=1 gateway=192.168.30.1 routing-mark=to_WAN3
add check-gateway=ping distance=2 gateway=192.168.20.1
add check-gateway=ping distance=3 gateway=192.168.30.1
/radius
add address=10.10.10.1 secret=1234 service=hotspot
/radius incoming
set accept=yes
/tool user-manager router
add coa-port=1700 customer=admin disabled=no ip-address=10.10.10.1 log=\
auth-fail name=mikrotik shared-secret=1234 use-coa=yes
normis
July 21, 2017, 12:02pm
5
You have specifically added Apple captive portal checks to walled garden. This does one thing - makes sure iPhone does not show popup. Why did you make that config?
How iPhone checks if there is a login page:
Connects to some WiFi point
Checks if it can open “captive.apple.com ” in background
now a very important thing happens!
A) IF it understands the contents, it means there is no hotspot, and it does nothing.
B) IF it does not understand the content, it means that some Login page is present. it then pops open the login page.
You have added the checking mechanism to walled garden, so iPhone never knows that there is a login page (variant A)
ne30n2
July 21, 2017, 2:07pm
6
Hi Normis,
Before posting this post, if have done some research on this.
As the login page does not show up, I did as following (as mentioned in the question)
add the walled garden (meaning i did try adding and not adding this rule at the time the login page issue)
change hotspot dns to .go .net .com .de .local…
Maybe could you please suggest something else?
normis
7
delete all the walled garden rules and try again. then post new config
ne30n2
July 21, 2017, 2:29pm
8
Here it is Normis
add comment="bridge1: ether 4-5 as HOTSPOT" name=bridge1
add comment="bridge2: ether 6-7 as LAN" name=bridge2
set [ find default-name=combo1 ] disabled=yes
set [ find default-name=ether4 ] arp=reply-only name=ether4-HOTSPOT
set [ find default-name=ether5 ] arp=reply-only name=ether5-HOTSPOT
set [ find default-name=ether6 ] arp=reply-only name=ether6-LAN
set [ find default-name=ether7 ] arp=reply-only name=ether7-LAN
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/ip hotspot profile
/ip hotspot
add disabled=no interface=bridge1 name=hotspot1 profile=HOTSPOT
set [ find default=yes ] keepalive-timeout=1d on-login=\
"/tool fetch mode=http url=\"\"" on-logout=\
"/tool fetch mode=http url=\"\"" shared-users=unlimited \
unlimited
add add-arp=yes address-pool=pool_HOTSPOT disabled=no interface=bridge1 \
add add-arp=yes address-pool=pool_LAN disabled=no interface=bridge2 \
set admin access=\
add name=30day_shared1 name-for-users="" override-shared-users=1 owner=admin \
network=10.10.20.0
add address=10.0.0.1/24 comment="Access point IP to LAN" interface=bridge1 \
network=10.0.0.0
add address=10.0.0.1/24 comment="Access point IP to LAN" disabled=yes \
interface=bridge2 network=10.0.0.0
/ip cloud
set ddns-enabled=yes
gateway=10.10.10.1
10.10.20.1
/ip dns static
add address=10.10.10.1 name=wifi.com
bit-list
/ip firewall mangle
add action=accept chain=prerouting disabled=yes dst-address-list=WAN3
add action=mark-connection chain=input connection-mark=no-mark disabled=yes \
in-interface=ether3-WAN new-connection-mark=WAN3_conn passthrough=yes
add action=mark-routing chain=output connection-mark=WAN3_conn disabled=yes \
"PPC HOTSPOT: 7x for WAN1 (200Mbs) + 1x for WAN2 (30Mbs)" \
per-connection-classifier=src-address:5/0
src-address:5/1
src-address:5/2
src-address:5/3
src-address:5/4
"PPC LAN: 7x for WAN1 (200Mbs) + 1x for WAN2 (30Mbs)" connection-mark=\
WAN1_conn passthrough=yes per-connection-classifier=src-address:5/0
WAN1_conn passthrough=yes per-connection-classifier=src-address:5/1
WAN1_conn passthrough=yes per-connection-classifier=src-address:5/2
WAN1_conn passthrough=yes per-connection-classifier=src-address:5/3
WAN2_conn passthrough=yes per-connection-classifier=src-address:5/4
add action=mark-routing chain=prerouting connection-mark=WAN3_conn disabled=\
yes new-routing-mark=to_WAN3 passthrough=yes src-address-list=LAN_HOTSPOT
ether1-WAN
add action=masquerade chain=srcnat disabled=yes out-interface=ether3-WAN
add check-gateway=ping comment=Gateway distance=1 gateway=192.168.10.1 \
add check-gateway=ping disabled=yes distance=1 gateway=192.168.30.1 \
add check-gateway=ping comment=\
"Failover: if one of the WAN fail, swtich to the next" distance=1 \
add check-gateway=ping disabled=yes distance=3 gateway=192.168.30.1
/radius
/radius incoming
set accept=yes
/tool user-manager database
set db-path=user-manager
