Logging in via winbox under the routerboard selection I see this:
Now I am running v5.23
What does Current version 2.27 mean?
What will upgrading to version 3.02 do for me?
If I click “Upgrade” will it do it automatically, or does the device have to be connected to the internet?
This is only a guess, but is it upgrading the ‘Fail Safe’ backup version that is stored onboard in case a version update completely locks us out?
The routerboard search after updates if it connect with internet
Just click on the upgrade button if the version is different.
Just like the picture you have posted
This command shows the current RouterBOOT version of your device, and available upgrade which is either included in routerboard.npk package . . . .
Does that mean it is ALREADY in the router and I don’t have to worry about being connected to the internet?
That’s how I am reading that, I just want to make sure that my understanding is correct.
and;
. . . . , or if you uploaded a FWF file corresponding to device model:
Would that be simply dragging and dropping the *.fwf file into the “Files” section of Winbox?
I find that the instructions there to be not very detailed at all, and this is what I am assuming. Can you confirm that for me?
Yes, you can. In your case: run command
/system routerboard upgrade
and
/system reboot
your routerboot version will be upgraded to 3.02
and;
YES, you can manualy download file from website and using dragg and dropp
Ok, I found it on the http://tiktube.com/ website.
There was a video there from a MUM conference that explained that the “Firmware” comes with the OS version updates.
It also said that you have to do the OS version update FIRST.
After that, you can apply the Firmware update.
Maybe I am missing it, but the Manual / Wiki really should say things like that, and if it does I am not seeing it.
