I am trying to implement QoS primarily for VoIP and Video packets. I found a script that did that and more that I’m attempting to adapt to my configuration.
With the below configuration I can see that traffic is hitting my mangle rules. When I look at the Queue Tree, my IN, OUT do not show any packets moving through.
This is on a CRS125-24G-1S-RM running 6.10
Interface Queues are all set to only-hardware-queue. Not sure if this affects anything.
Any help would be appreciated, thank you. ![]()
/ip firewall layer7-protocol
add name=speedtest-servers regexp="^.*(get|GET).+speedtest.*\$"
add name=torrent-wwws regexp="^.*(get|GET).+(torrent|thepiratebay|isohunt|ente\
rtane|demonoid|btjunkie|mininova|flixflux|vertor|h33t|zoozle|bitnova|bitso\
up|meganova|fulldls|btbot|fenopy|gpirate|commonbits).*\$"
add name=torrent-dns regexp="^.+(torrent|thepiratebay|isohunt|entertane|demono\
id|btjunkie|mininova|flixflux|vertor|h33t|zoozle|bitnova|bitsoup|meganova|\
add name=netflix regexp="^.*(get|GET).+(netflix).*\$"
add name=mp4 regexp="^.*(get|GET).+\\.mp4.*\$"
add name=swf regexp="^.*(get|GET).+\\.swf.*\$"
add name=flv regexp="^.*(get|GET).+\\.flv.*\$"
add name=video regexp="^.*(get|GET).+(\\.flv|\\.mp4|netflix|\\.swf).*\$"
/queue tree
add max-limit=30M name=in parent=global
add max-limit=5M name=out parent=global
/queue type
add kind=pfifo name=streaming-video-in pfifo-limit=500
add kind=pcq name=games-in-pcq pcq-classifier=dst-address \
pcq-dst-address6-mask=64 pcq-rate=100k pcq-src-address6-mask=64 \
pcq-total-limit=750000
/ip firewall address-list
add address=192.168.1.0/24 list=support
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A" list=bogons
add address=127.0.0.0/16 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B" list=bogons
add address=192.168.0.0/16 comment="Private[RFC 1918] - CLASS C" disabled=yes \
list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment="MC, Class D, IANA" list=bogons
add address=192.168.1.0/24 list=internal-nets
add address=172.249.240.0/20 list=external-nets
add action=add-src-to-address-list address-list=Syn_Flooder \
address-list-timeout=30m chain=input comment=\
"Add Syn Flood IP to the list" connection-limit=30,32 protocol=tcp \
tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" \
src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner \
address-list-timeout=1w chain=input comment="Port Scanner Detect" \
protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" \
src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=\
ICMP protocol=icmp
"Block all access to the winbox - except to support list" dst-port=8291 \
protocol=tcp src-address-list=!support
add action=jump chain=forward comment="Jump for icmp forward flow" \
jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
bogons
add action=add-src-to-address-list address-list=spammers \
address-list-timeout=3h chain=forward comment=\
"Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=\
25,587 limit=30/1m,0 protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 \
protocol=tcp src-address-list=spammers
add chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add chain=input comment="Full access to SUPPORT address list" \
src-address-list=support
add chain=ICMP comment="Echo request - Avoiding Ping Flood" icmp-options=8:0 \
limit=1,5 protocol=icmp
add chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=icmp
add chain=ICMP comment="Time Exceeded" icmp-options=11:0 protocol=icmp
add chain=ICMP comment="Destination unreachable" icmp-options=3:0-1 protocol=\
icmp
add chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP \
protocol=icmp
add chain=input comment="Accept to established connections" connection-state=\
established
add chain=input comment="Accept to related connections" connection-state=\
related
add chain=forward comment="Allow LAN access to router and Internet" \
connection-state=new in-interface=ether2-master-local
add chain=forward comment="Forward to established connections" \
connection-state=established
add chain=forward comment="Allow UPnP dynamic NAT rules" dst-address=\
192.168.1.0/24
add chain=forward comment="Forward to related connections" connection-state=\
related
add action=drop chain=input comment="Drop all input"
add action=drop chain=forward comment="Drop all forward"
/ip firewall mangle
add action=mark-packet chain=prerouting comment=\
"internal-traffic packet mark" dst-address-list=internal-nets \
new-packet-mark=internal-traffic passthrough=no src-address-list=\
internal-nets
add action=mark-packet chain=prerouting comment="admin-in packet mark DNS" \
in-interface=ether1-gateway new-packet-mark=admin-in passthrough=no \
protocol=udp src-port=53
add action=mark-packet chain=prerouting comment="admin-in packet mark snmp" \
dst-port=161 in-interface=ether1-gateway new-packet-mark=admin-in \
passthrough=no protocol=udp
add action=mark-connection chain=prerouting comment=\
"Remote Protocols admin connection mark" new-connection-mark=admin port=\
20,21,22,23,3389,8291 protocol=tcp
"icmp connection mark as admin" new-connection-mark=admin protocol=icmp \
src-address-list=internal-nets
add action=mark-packet chain=prerouting comment="admin-in packet mark" \
connection-mark=admin in-interface=ether1-gateway new-packet-mark=\
add action=mark-packet chain=prerouting comment="admin-out packet mark" \
connection-mark=admin new-packet-mark=admin-out passthrough=no
"streaming video connection mark" dst-port=80 layer7-protocol=video \
new-connection-mark=streaming-video protocol=tcp src-address-list=\
internal-nets
"streaming video in packet mark" connection-mark=streaming-video \
in-interface=ether1-gateway new-packet-mark=streaming-video-in \
passthrough=no
"streaming video out packet mark" connection-mark=streaming-video \
new-packet-mark=streaming-video-out passthrough=no
"http traffic connection mark" dst-port=80,443 new-connection-mark=http \
protocol=tcp src-address-list=internal-nets
"http traffic connection mark" connection-bytes=5000000-4294967295 \
dst-port=80,443 new-connection-mark=http-download protocol=tcp \
add action=mark-packet chain=prerouting comment="http in packet mark" \
connection-mark=http in-interface=ether1-gateway new-packet-mark=http-in \
passthrough=no
add action=mark-packet chain=prerouting comment="http out packet mark" \
connection-mark=http new-packet-mark=http-out passthrough=no
"wow connetion mark as gaming" dst-port=\
1119,3724,6112-6114,4000,6881-6999 new-connection-mark=games protocol=tcp \
"eve online connetion mark as gaming" dst-address=87.237.38.200 \
new-connection-mark=games src-address-list=internal-nets
"starcraft 2 connetion mark as gaming" dst-port=1119 new-connection-mark=\
games protocol=tcp src-address-list=internal-nets
"heros of newerth connetion mark as gaming" dst-port=11031,11235-11335 \
new-connection-mark=games protocol=tcp src-address-list=internal-nets
"steam connetion mark as gaming" dst-port=27014-27050 \
"xbox live connetion mark as gaming" dst-port=3074 new-connection-mark=\
"ps3 online connetion mark as gaming" dst-port=5223 new-connection-mark=\
"wii online connetion mark as gaming" dst-port=28910,29900,29901,29920 \
"games packet mark forever-saken-game" dst-address-list=external-nets \
new-packet-mark=games-in passthrough=no src-address-list=\
forever-saken-game
add action=mark-packet chain=prerouting comment="games packet mark wow" \
dst-address-list=external-nets new-packet-mark=games-in passthrough=no \
protocol=udp src-port=53,3724
"games packet mark starcraft2" dst-address-list=external-nets \
new-packet-mark=games-in passthrough=no protocol=udp src-port=1119,6113
add action=mark-packet chain=prerouting comment="games packet mark HoN" \
protocol=udp src-port=11031,11235-11335
add action=mark-packet chain=prerouting comment="games packet mark steam in" \
port=4380,28960,27000-27030 protocol=udp
add action=mark-packet chain=prerouting comment="games packet mark steam out" \
dst-port=53,1500,3005,3101,3478,4379-4380,4380,28960,27000-27030,28960 \
new-packet-mark=games-out passthrough=no protocol=udp src-address-list=\
internal-nets
add action=mark-packet chain=prerouting comment="games packet mark xbox live" \
protocol=udp src-port=88,3074,3544,4500
"games packet mark ps3 online" dst-address-list=external-nets \
new-packet-mark=games-in passthrough=no protocol=udp src-port=\
3478,3479,3658
add action=mark-packet chain=prerouting comment="games packet mark in" \
connection-mark=games dst-address-list=external-nets new-packet-mark=\
add action=mark-packet chain=prerouting comment="games packet mark out" \
connection-mark=games new-packet-mark=games-out passthrough=no
"voip-in packet mark teamspeak" dst-address-list=external-nets \
new-packet-mark=voip-in passthrough=no protocol=udp src-port=9987
"voip-out packet mark teamspeak" dst-port=9987 new-packet-mark=voip-out \
passthrough=no protocol=udp src-address-list=internal-nets
"voip-out packet mark teamspeak" dst-address-list=external-nets \
"voip-in packet mark ventrilo" dst-address-list=external-nets \
new-packet-mark=voip-in passthrough=no protocol=udp src-port=3784
"voip-out packet mark ventrilo" dst-port=3784 new-packet-mark=voip-out \
new-packet-mark=voip-in passthrough=no protocol=tcp src-port=3784
passthrough=no protocol=tcp src-address-list=internal-nets
add action=mark-packet chain=prerouting comment="voip-in packet mark SIP" \
dst-address-list=internal-nets new-packet-mark=voip-in passthrough=no \
port=5060 protocol=tcp
add action=mark-packet chain=prerouting comment="voip-out packet mark SIP" \
new-packet-mark=voip-out passthrough=no port=5060 protocol=tcp \
add action=mark-packet chain=prerouting comment="voip-in packet mark udp SIP" \
port=5004,5060 protocol=udp
"voip-out packet mark udp SIP" new-packet-mark=voip-out passthrough=no \
port=5004,5060 protocol=udp src-address-list=internal-nets
add action=mark-packet chain=prerouting comment="voip-in packet mark RTP" \
dst-address-list=internal-nets new-packet-mark=voip-in packet-size=\
100-400 passthrough=no port=16348-32768 protocol=udp
add action=mark-packet chain=prerouting comment="voip-out packet mark RTP" \
new-packet-mark=voip-in packet-size=100-400 passthrough=no port=\
16348-32768 protocol=udp src-address-list=internal-nets
add action=mark-packet chain=prerouting comment="vpn-in packet mark GRE" \
in-interface=ether1-gateway new-packet-mark=vpn-in passthrough=no \
protocol=gre
add action=mark-packet chain=prerouting comment="vpn-out packet mark GRE" \
new-packet-mark=vpn-out passthrough=no protocol=gre
add action=mark-packet chain=prerouting comment="vpn-in packet mark ESP" \
protocol=ipsec-esp
add action=mark-packet chain=prerouting comment="vpn-out packet mark ESP" \
new-packet-mark=vpn-out passthrough=no protocol=ipsec-esp
"vpn-in packet mark VPN UDP ports" in-interface=ether1-gateway \
new-packet-mark=vpn-in passthrough=no protocol=udp src-port=500,1701,4500
"vpn-out packet mark VPN UDP ports" new-packet-mark=vpn-out passthrough=\
add action=mark-packet chain=prerouting comment="vpn-in packet mark PPTP" \
protocol=tcp src-port=1723
add action=mark-packet chain=prerouting comment="vpn-out packet mark PPTP" \
new-packet-mark=vpn-out passthrough=no protocol=tcp src-port=1723
add action=mark-packet chain=prerouting comment="all in" in-interface=\
ether1-gateway new-packet-mark=in passthrough=no
add action=mark-packet chain=prerouting comment="all out" new-packet-mark=out \
passthrough=no
add action=masquerade chain=srcnat comment=\
"Local Network NAT Masquerade Rule" out-interface=ether1-gateway \
to-addresses=0.0.0.0
