first Cap AX as a bridge - setup OK?
Newbie got his (my) first CapAX up and running in bridge mode and it is working as far as I can see.
Proabably more “dirty” than “quick”, so I am sure my config neeeds cleanup :confused: i.e. removing unneccesary settings, correcting settings…
In general I try to keep the config simple as I am still not familiar with MT at all:
CapAX shall act as an AP in bridge mode, providing 192.168.178.0/24 network to my 2.4 GHz and 5 GHz WiFi clients.
No need for firewall, or does it real make sense to have one behind the ISP router Firewall?
So any advice is appreciated.
Also…I’d like to see the hostnames in “WIFI/Registration” or “QuickSet Local/Clients” - can somehow explain how to achieve this?
DHCP is provided by my ISP router. I am sure I can create a list with IP, Hostname and MAC if it would be useful.
Txs guys
# 2024-01-23 14:47:04 by RouterOS 7.13.2
# software id = XGEA-TLYF
# model = cAPGi-5HaxD2HaxD
# serial number = redacted
add admin-mac=48:A9:8A:E4:FE:BD auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5560 \
    .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.country=\
    Germany .mode=ap .ssid=DarkStar-5 disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .connect-priority=0 .ft=\
    yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .frequency=2437 \
    .skip-dfs-channels=disabled .width=20/40mhz configuration.country=Germany \
    .mode=ap .ssid=DarkStar-2 disabled=no security.authentication-types=\
    wpa2-psk,wpa3-psk .connect-priority=0 .ft=yes .ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge interface=ether1
add comment=defconf interface=ether1 list=LAN
/interface wifi access-list
add action=accept disabled=no mac-address=30:58:90:75:2C:5C
    192.168.88.0
/ip dhcp-client
add comment=defconf interface=bridge
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
/ipv6 firewall address-list
/system clock
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes manycast=yes
/system ntp client servers
add address=192.168.178.55
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
Comments:
  • if you are comfortable with firewall on ISP router, no need to have one on cAP AX too
  • if you want to use FT (Fast Transition) which your settings seem to indicate, it does not make sense to have different SSIDs for 2.4GHz and 5GHz radios.
  • this config is not needed since not used
    192.168.88.0
    192.168.88.1
/ip dns static
@holvoetn
txs for checking and hints. Changed SSIDs to one, removed the dns-static and dhcp entries, but wasn’t able to remove the first two entries in terminal.
“print” in /ip pool results in empty line, same as within /ip address. Probably a dummie’s issue…
But not mission critical as the cap AX is performing well so far.
Try
/ip pool export
and
/ip address export
