First Clue for learning on using KVM
Hi guys, this is my first topic and my first post too.. :slight_smile:
I’am interesting to learning this virtualization on mikrotik, because we can get some easiness to just have a one baremetal, to make more than one server. but I find some confuse to start learning this. I have dom with 4.11 installed on it, and have the baremetal too. maybe Can I have some clue to using this KVM. maybe on making the image of the OS to be installed to the kvm guest ??
thanks for your kindness.. :smiley:
You can start by reading KVM manual
http://wiki.mikrotik.com/wiki/Kvm
There are step by step instructions how to make guest images, add KVM guests etc.
thanks for the clue. i’m starting to create the guest, but I ran into this
[admin@MikroTik] > kvm pr
Flags: X - disabled
 0   disk-images=hda:/sata1/ubuntu-10.10-server-i386.iso initrd="" kernel=""
     kernel-cmdline="" name="ubuntuserver" cpu-count=2 memory=512MiB
     snapshot=no vnc-server=192.168.3.2:10 state=failed
[admin@MikroTik] >
if change the value of vnc-server to 0.0.0.0, the state is running. but when I give an IP address, state become failed. I found this too when I shut-down the guest and set the IP.. :confused:
Thank you :slight_smile:
okay, the state is running, I was wrong to see the IP address of the server.. my mistake.. :open_mouth:
but when I using the VNC viewer, It’s failed to boot.. :frowning:
edited :
fill the initrd and kernel with file from the guest OS.. it should solve the problem.. :slight_smile:
Seems that now I can boot the ubuntu server : :smiley: , but now the problem is that I can’t mount the cd-rom when I try to install the OS.. someone can help ??
Thank’s for your kindness.. :slight_smile:
you cannot mount CDROM, you should use ISO image of the CD you are trying to use and add it as cdrom: where disk-images are configured
sorry for the long time to reply this topic.. thanks for the reply..
it seems that I can’t detect the disks when I try to install the OS. It look’s like this
how can I use the HDD on my desktop ?? any clue ?? thanks by the way.. :smiley:
P.S :
this is config for adding the VM :
[admin@MikroTik] > /kvm pr
Flags: X - disabled
 0   disk-images=cdrom:/sata2/ubuntu-10.10-server-i386.iso
     initrd="/sata2/initrd" kernel="/sata2/vmlinuz" kernel-cmdline=""
     name="ubuntuserver" cpu-count=1 memory=256MiB snapshot=no
     vnc-server=192.168.3.1:10 state=running
in RouterOS using KVM you cannot assign physical partitions/disks to virtual guest. You have to create file for that use.
thanks for the answer.
I found your post from another topic about kvm too, and you wrote this:
with label cdrom you tell kvm that you will be using iso image as cdrom and not as a normal storage disk drive. Things like read-only are set by default.
regarding files all you have to do is upload ISO/image file you want to install OS from, and make storage file that will be used as guest hard drive.
and i wanna ask something, how can I make the storage file ? did you mean by “make-router-image”, or another command ?
thank you :slight_smile:
yes, with make-routeros-image. That is easiest way how to create file inside RouterOS.
thanks for the reply, seems that I can install the windows OS, and I can run it on VNC.
I install ubuntu server too, but when the OS need to restart, the state become failed. :frowning:
I tried to edit the disk-image, change the value. the problem is, I can’t do “save-and-quit”.
I wanna ask, what is the shortcut for “save-and-quit” ?
thanks :slight_smile:
if i understood you correctly, then that is ‘Ctrl+o’
yes that’s what I mean. but it doesn’t work. I tried all the keyboard button for the shortcut.. still I can’t change the value.. :open_mouth:
should I restart it or how? :confused:
I think I found the solution, I skip the cdrom boot process, so I can boot from the image file.. thanks for your support, sir.. :smiley:
maybe I run some test first.. :slight_smile:
