Hello, I’m trying to connect to a 951G RouterBoard with no success.
When I powered on the board for the first time I didn’t see the wireless SSID as stated on the user guide.
I’ve tried to reach the router via ethernet using the DHCP or a static 192.168.88.x IP but still with no result.
In the Winbox 3 click Neighbour Tab, then wait a while to see if it finds your router.
If no, there is real problem…maybe you need to netinstall
If yes, click the Mac field to connect via MAC address to bypas problem of IP address conflict if your LAN card has static IP set and it is not “compatibile” with default 192.168.88.0/24.
When you click MAC field then in the upper field the MAC will be copied instead of IP, rest of the process is the same
