Hi forum, I’m trying to achieve this configuration and in the meantime some questions arise..
I’d like to use the “ISP ROUTER” subnet for:
default gateway (double nat isn’t a problem, just for testing)
management subnet for all the RB and APs
static ip for the CAPsMAN manager (CRS112)
The CRS112 will be used for serving VLANs + DHCP and will be the default gateway for them. Port 1-7 will be trunk and 8 for WAN uplink to ISP ROUTER.
The APs will have separate SSID associated with the VLANs (PVID?), i’d like to use the hAP AC2 as AP + switch (2+2 port for VLAN11 and 12)
First question: I can’t really understand where put VLAN interfaces. On each eth without bridge? On the eth1 then bridge the others eth? On the bridge (port member 1-7)? On bridge menu / VLANs?
Second question: How can I “extend” the default ISP ROUTER subnet to the other APs?
I’m not fully confident about this setup, any help or advice is appreciated
I think requirements drive both design and config but keeping your design as is…
Sure just assign the LAN subnet coming from the ISP router a vlan tag on the way into the CRS.
Then you can distribute it tagged or untagged as you require.
Ty anav, I’m moving forward and I would like to keep you updated so as to improve or correct any errors.
Next step will be configure CAPsMAN on the CSR112 and setup ssid with separate VID
Some other questions/improvements:
For CAPsMAN manager i’d like to use an internal management, how to do it? Dhcp client of the APs need to be different?
Using the ISP ROUTER subnet from a port of an access port of a remote AP, the ingress of that port need a PVID set?
For blocking inter-VLAN routing is better to use vlan filtering or firewall?
