Hi all!
I’m trying to gauge the viability of migrating from Ubiquiti EdgeOS to Mikrotik RouterOS. I have gigabit internet at home from AT&T that uses dot1.x authentication with a certificate on the router they provided. With Ubiquiti I’m able to duplicate all traffic from the ISP, send the dot1.x traffic to the AT&T router, while all the other traffic goes to my router. Can I do the same with Mikrotik? Below are the steps for EdgeOS… please advise if I can accomplish the same in RouterOS.
Taken from: http://bzsparks.com/2016/10/05/using-an-ubiquiti-edgerouter-with-att-gigapower-fiber/
Create the bridge interface:
set interfaces bridge br0
Add eth1 and eth2 to br0
set interfaces ethernet eth1 bridge-group bridge br0
set interfaces ethernet eth2 bridge-group bridge br0
create a sub-interface on br0 with your static IP.
set interfaces bridge br0 vif 0 address X.X.X.X/X
set your routing
set protocols static route 0.0.0.0/0 next-hop X.X.X.X
define a source NAT masquerade rule for the br0.0 interface
set service nat rule 5000 outbound-interface br0.0
set service nat rule 5000 type masquerade
Next we need to allow the gateway to pass auth traffic through the bridge
echo 8 > /sys/class/net/br0/bridge/group_fwd_mask
Because of the nature of an interface bridge all traffic is copied to both interfaces. Running a tcpdump on the Arris interface shows all ingress and egress traffic. To only allow 802.1X/EAP traffic to the gateway we need to use ebtables.
ebtables -t filter -A FORWARD -i eth2 -p 802_1Q --vlan-encap 0x888e -j ACCEPT
ebtables -t filter -A FORWARD -i eth2 -p 802_1Q -j DROP
ebtables -t filter -A FORWARD -o eth2 -p 802_1Q --vlan-encap 0x888e -j ACCEPT
ebtables -t filter -A FORWARD -o eth2 -p 802_1Q -j DROP
Finally, we need to spoof our br0.0 MAC address so that it presents itself as the AT&T gateway. Run these commands as root.
ip link set br0.0 down
ip link set br0.0 address XX:XX:XX:XX:XX:XX
ip link set br0.0 up
Remember every time that br0.0 is created it needs to have its MAC spoofed, this means on every reboot. To accomplish this we will create a simple script in /config/scripts/post-config.d/
#!/bin/bash
