First set o rules don't work if I enabled another set of rules
Hi all,
I created a set of rules that you can see below, everything works fine, no complaints.
  1. PPTP client (mikrotik) - connected to a PPTP Server
  2. /ip firewall nat add action=masquerade chain=srcnat out-interface=PPTP
  3. /ip firewall mangle add action=mark-routing chain=prerouting new-routing-mark=PPTP src-address=192.168.88.0/24
  4. /ip route add distance=1 dst-address=172.23.241.250/32 gateway=PPTP routing-mark=PPTP
But if enable another set of rules you can see below then the first set of rules don’t work anymore, why does this happen?
  1. PPTP client (mikrotik) - connected to another mikrotik PPTP Server
  2. /ip firewall nat add action=masquerade chain=srcnat out-interface=PPTP_2
  3. /ip firewall mangle add action=mark-routing chain=prerouting new-routing-mark=PPTP_2 src-address=192.168.88.0/24
  4. /ip route add distance=1 dst-address=172.16.11.120/32 gateway=PPTP_2 routing-mark=PPTP_2
Thank you.
PPTP_1 and PPTP_2 are both 172.23.241.250/32 ?
A packet from 192.168.88.0/24 destined to 172.23.241.250 will first have it’s routing mark set to PPTP_1, but then the next mangle rule changes that mark to PPTP_2 and the packet will go out on PPTP_2.
No no, sorry I’ve made a mistake, I edited the first post, second route is to: 172.16.11.250
How to configure so that both set o rules would work together?
Anybody ?
Your mangle rules need to have different criteria.
The first mangle rule sets the routing mark to PPTP when the src address is 192.168.88.0/24.
Then the second rule will change that routing mark to PPTP_2 when the src address is 192.168.88.0/24
Thus all packets will always go out the second route.
What are you trying to do?
