First setup of a LTE Cat6 Kit
Hi, first post here, my name is Tommy i’m trying to setup a LTE Cat6 router.
My goal would be to use that just as a modem in pair with a couple of Google wifi Nest to use as a router (their def network setup is on 192.168.86.1).
In the configuration i have today on the kit dhcp is enabled, if i plug in into the WAN port of any router he get over and the kit become the router, while i would like the Nest to play that role.
should i just disable the dhcp and either assign a specific ip within the 192.168.86.x space or enable the dhcp client? would that work?
thanks a lot!
