Is there any “First time config” article on Wiki for CCR. I have tried almost everything.
Touch is not calibrated I think, because of which I am unable to use the touch screen properly.
Unable to connect to the router using Winbox.
Serial console is also not working.
I am stuck for this.
clarify what is not working please. which port did you connect to? what is the error in winbox and in serial console? did you try the […] button in winbox to search for MAC address of the port?
this is a good first time guide: http://wiki.mikrotik.com/wiki/Manual:First_time_startup
Got it working after doing the RESET.
It will be great if the touch screen comes pre-calibrated.
mudasir, touchscreen does come pre-calibrated. maybe something was wrong on your particular device. happy to hear you got it working!
After a reset the calibration of my display is completely wrong, like if it had been flipped 180º.
The upper right corner is swapped with the bottom left corner.
Upper left and bottom right corners work fine though.
After recalibration everything is ok.
Seen that, what the system REALLY SHOULD DO is launch calibration after a reset, or at least have it in the main menu maybe.
UPDATE: Upgraded to 6.0 and now it works fine after a reset.
