First Time setup of RB493G
This is my first time with MikroTik but have configured lots of other routers before.
I am stuck and not able to get the eth1 port to get the DHCP IP from my ISP.
Here is my current config.
add name=Lan_bridge
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n disabled=no frequency=auto ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 l2mtu=2290 mode=ap-bridge
/port
set 0 name=serial0
/ppp profile
set [ find name=default ] name=default
set [ find name=default-encryption ] name=default-encryption
add bridge=Lan_bridge interface=ether2
add bridge=Lan_bridge interface=ether3
add bridge=Lan_bridge interface=ether4
add bridge=Lan_bridge interface=ether5
add bridge=Lan_bridge interface=ether6
add bridge=Lan_bridge interface=ether7
add bridge=Lan_bridge interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=Lan_bridge network=192.168.88.0
/ip dhcp-client
add default-route-distance=0 disabled=no interface=ether1 use-peer-dns=no use-peer-ntp=no
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/system identity
set name=Router
/system routerboard settings
set protected-routerboot=disabled
/tool romon port
add disabled=no
The same model
It should work when doing that.
Are you sure you need to use plain ethernet and not PPPoE?
How is the router connected to your ISP?
