First time using Mikrotik product. Advises and help needed.
Hello everyone.
I’ve been reading the forum and looking for some situation like mine and I’ve found some, but as I’m not obtaining the results I expected I’ve decided to open a new message, so if you can help me I would be very grateful.
First of all let me introduce my situation and equipment.
My ISP provide me a 300/30Mbps Internet connection, and the goal is to obtain the bests results possible in a 200 - 250 meter with direct view between antennas.
The equipment is, 2x Mikrotik RBSXTG-5HPacD-SA, so they are a SXT ac antennas which (theoretically) have a 866Mbps transfer rate.
The setup I followed for the link are here: http://www.wispforum.net/entry.php?6-How-to-Connect-two-Mikrotik-SXT-5D-s-In-Bridge-Mode-Part-II&goto=prev and http://www.wispforum.net/entry.php?6-How-to-Connect-two-Mikrotik-SXT-5D-s-In-Bridge-Mode-Part-II
Having concerned that I have a short distance between points, I don’t know if my results are the best possible and I will be happy if you help me to interpret the results and to setup the equipment, because now I’m lost in a sea of configuration options.
Now let me to show you some information about my config, tests, and status of the antennas.
AP Side configuration:
[admin@MikroTik] > interface wireless print advanced
 0  R name="wlan1" mtu=1500 mac-address=XX:XX:XX:XX:XX arp=enabled
      disable-running-check=no interface-type=Atheros AR9888
      radio-name="XXXXXXXXXX" mode=bridge ssid="MikroTik" area=""
      frequency-mode=manual-txpower country=spain antenna-gain=0 frequency=
      band=5ghz-onlyac channel-width=20/40/80mhz-eeeC scan-list=default
      wireless-protocol=802.11 rate-set=default
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54
      basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic
      tx-power-mode=default dfs-mode=none vlan-mode=no-tag vlan-id=1
      wds-mode=dynamic wds-default-bridge=bridge1 wds-default-cost=100
      wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabl
      bridge-mode=enabled default-authentication=yes default-forwarding=yes
      default-ap-tx-limit=0 default-client-tx-limit=0
      proprietary-extensions=post-2.9.25 wmm-support=enabled hide-ssid=yes
      security-profile=default disconnect-timeout=3s on-fail-retry-time=100
      preamble-mode=both compression=no allow-sharedkey=no
      station-bridge-clone-mac=00:00:00:00:00:00 ampdu-priorities=0
      guard-interval=any
      ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-
                 9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,
                 18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
      ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
https://www.dropbox.com/s/qg822quvv8hkgp2/ap_1.PNG?dl=0
https://www.dropbox.com/s/fbs24gugvqv7gt0/ap_2.PNG?dl=0
(I am using 802.11 protocol because I’m making tests).
Now in the client side:
      radio-name="XXXXXXXXXX" mode=station-bridge ssid="MikroTik" area=""
      frequency-mode=manual-txpower country=spain antenna-gain=0 frequency=5700
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
      wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
      proprietary-extensions=post-2.9.25 wmm-support=enabled hide-ssid=no
      security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
      guard-interval=any
      ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-
                 9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-
https://www.dropbox.com/s/pkcll8oz80dhwas/client_1.JPG?dl=0
https://www.dropbox.com/s/o0vtiva3txm3aa5/client_2.JPG?dl=0
Now the tests:
https://www.dropbox.com/s/a4qprqe2s6dgxgg/TEST_CLIENT.JPG?dl=0
https://www.dropbox.com/s/cmyx588qzu112do/TEST_CLIENT_UDP.JPG?dl=0
So what do you think about the tests and the results. How can I improve performance?.
Thank you very much for your help and answers, hope you can help me.
Yes. Thats the best result coz you got wds on. Wds cuts your bandwidth,
Your signal is too strong. Try to reduce TX power in order to get about -50
SA SXT are Sector Antenna. You should have chosen SXT5AC to do PtP
Regards
