Fit-PC2i as Router?
Does anyone have experience with fit-PC2i, or etc. as hardware for RouterOS?
Or any ideas on powerful high performance, low power hardware for routing & QoS L7 applications. (minimal dual core 1,6GHz+, 1GRAM+, 2xGLAN).
Looks like it would be a pretty powerful router :slight_smile: you should try it!
I have one however encountered strange issues with interfaces not showing up after reboots.
I’ve just moved into a new house and have been trying to find where I put it as I’d like to try running up ESXi and Mikrotik on top of that.
Will keep you posted if/when I find mine :stuck_out_tongue:
