I think I found a bug in the 5.0 UI.
If I take a rule which was a simple mark packet rule, and convert it to a mark connection rule, then copy that mark connection rule so I can turn the copy into a mark packet rule based on the connection mark, I get an error when I apply. The error is that I can’t specify ports unless I use FTP or UDP protocol, but when I’m hitting apply I’ve already eliminated the protocol and ports. The only thing I’m using at that point is the connection mark, but it’s like the UI still thinks the ports are selected.
I show the process in the pictures below, but I didn’t realize the last posted pick goes at the top. Read the pics from bottom to top. I start with the rule shown in the bottom pick, copy and edit it (middle pick) and then apply (top pic) and get the error.
Greg
