Fix the BGP crashes
My vote for ROSv5 is fixing the BGP crashes.
Thanks,
Sotiris
v5??? why not fix the errors in v4? :slight_smile:
and a button in Winbox: ‘make it working the way it should be’ =)
All know BGP crashes were fixed. If you still have BGP problems in v4.2 then please contact support@mikrotik.com
How all the BGP crashes were fixed ther is a post in the forum with problems with BGP on version 4.2.
Can someone provide details if they have 4.2 BGP working proberly and also how many peers and routes they have???
Thanks,
Sotiris
To which one of articles you are referring?
And if you have any problems contact support with detailed problem description as I mentioned in previous post.
Hello mrz,
as I see from your link here you say BGP on 4.2 is working ok with no noticable problems
http://forum.mikrotik.com/t/taking-full-bgp-routes-resources-rb1000/32925/2
What are the not noticable problems ???
I’ll give it a go with 4.2 but I had a few problems with configuration transfer all the VLANs loose their interface when you upgrade to 4.2.
Thanks,
Sotiris Ioannou
