Hello I am new to Mikrotik but so far I really like it! I have a question that I do not seem to be able to search up the correct answer.
I have a new RB750 and I set up a VPN successfully. I will have two devices I need to reach. The first device I configured for DCHP and I setup a lease in the RB750. I can reach this device with no problems and the connections and routes are reported by the RouterOS.
My second device is the problem. It will only allow me to enter a fixed IP, netmask, and gateway. I will report what I have tried but so far I am only able to ping it and nothing else. I am able to place it on my home network which uses another router brand and do all I need, but I am trying to set this up for a system that will use the Mikrotik in many places if I succeed.
I would like to use an address on the internal network for example the device that does work I setup the lease for 192.168.88.11. I am trying to use 192.168.88.10 for the device I can not reach except for ICMP. I tried setting up a lease for the device but since internally it is already fixed I do no think this helps.
The device does show up in the arp list. I have tried fire wall rules and routes to try to get to the unit with TCP and port 80.
I tried to set it up like a gateway applying the address 192.168.88.9 to the ether5-local-slave and routing it to 192.168.88.10 and the route shows up and says it is reachable but I don’t reach it ![]()
What should I try?
Thanks is advance
Bruce
