Fixed IP on Mikrotek
Hi folks,
I encountered a problems with my network connection not stable. I have around 400 client connect to the network using Mikrotek.
I recently set fixed IP to all the client I am not sure if that the root of the problems. Since then the problems fixed every time I restarted the Mikrotek. It happened almost every day.
Hope everyone can guide me what to deal with it.
Thank you.
No one can help you with such a vague problem description.
It is not clear what exactly means “not stable” - is the download speed jumping, do some connections time out, are some web servers unreachable while others work…
Nor it is 100% clear from what you wrote whether you’ve assigned static addresses to the clients as an attempt to resolve the problems, or whether you suspect this change to cause of the problems (that’s how I understand what you wrote).
If you want assistance.
a. post a network diagram
b. post your complete config
/export hide-sensitive file=anynameyouwish (and ensure your wanip and gateway are removed, and use codetags above when posting the text)
