Hi
yesterday I found I can not enable ssh on RB450G which was good before.Ticket#2011041766000013 was sent to MT.
thanks for help!!
[admin@MikroTik] > ip service print
# NAME PORT ADDRESS CERTIFICATE
0 X telnet 23 0.0.0.0/0
1 ftp 21 192.168.88.0/24
2 www 80 192.168.88.0/24
3 X ssh 22 192.168.88.0/24
4 X www-ssl 443 0.0.0.0/0 none
5 X api 8728 0.0.0.0/0
6 winbox 8291 0.0.0.0/0
[admin@MikroTik] > user ssh-keys print
# USER KEY-OWNER
error - contact MikroTik support and send a supout file (2)
[admin@MikroTik] > ip service enable ssh
[admin@MikroTik] >
I had this problem (same hardware) when testing v5.x and going forth & back to v4.17. ssh service was declared invalid. One difference with you, IP range for clients wasn’t limited for ssh.
When rebooting with v4, I notice some message one console about ssh server keys being generated… each boot.
What I did to solve this (it’s absolutly no “clean” nor official, but couldn’t find another way): upload rOS v5.0 or rc12 unified npk. Do upgrade reboot. upload v4.17 unified npk, Do downgrade reboot… And should be solved. Another reboot (with v4.17 now) should not show any ssh key related message on console.
from your answer, I thought, if we need downgrade , then we must downgrade from 5.1->4.17, we should go 5.0 then 4.17.
if it was true, what if I want to downgrade to 3.30,that many versions I have to do it one by one?
